RonR wrote:The driveshaft rebuild continues...
Just found a replacement tripod for the inner CV joints - It's a GI69 tripod with 30 splines - GKN have a "motorsport" version listed as part number MS3H002. I've ordered one, trial fitted it and - it fits on the N/S (L/H) shaft. Don't see why they would have used a different one on the O/S but I'll be trying it in the next few days and will report back here.
Hello,
I’m sorry to inform you that we do not have any dimensions on hand for this part. However, if you can provide me with the OEM part number of the part you need, I’ll be able to find the perfect match for your vehicle if we have it. You can get this OEM part number by calling your dealership and provide them with your VIN number. Ask them for the full OEM part number for the part you need. Let me know this number and I’ll be able to take care of you if we carry the specific part.
dapinky wrote:Joao,
Can you give them the GKN part number and see if they can supply it (or one to the same specifications)?
They were not a tight fit by design - What do you think is worn?Tuga2112 wrote:i have fitted one in my driver's side as part of other work on the jackshaft (basically i swapped the tripod and bearing to confirm that the shaft itself is worn)
Simon_P wrote:They were not a tight fit by design - What do you think is worn?Tuga2112 wrote:i have fitted one in my driver's side as part of other work on the jackshaft (basically i swapped the tripod and bearing to confirm that the shaft itself is worn)
