[/color]Blaster wrote:I had the same issue last year so initially went for the later map then added the O2 sensor. I still have the later map if you want to try and an old Gunson CO meter that seems to read about right.
chrism wrote:So, it seems that to enhance fuel economy and reduce over-fuelling or partial-burning smell a 9930 or 1499 + O2 sensor upgrade would be the way to go - but neither are available now and probably won't be offered used, either(?)
chrism wrote:
TorqueHorse, I looked at your suggestion, thanks, and saw 'Turbo catalyst (except California)' Mine is an SE w/out a cat or wiring loom(?) which I suppose would make it extremely complicated to go 1499 via that ecu(?) I'd have to install an S2/Fed exhaust, for starters (?)
chrism wrote:Aw...that would've been the best news ever Fredjohn but my SE was reg'd on 3/12/90 and doesn't seem to have a blanking plug near the turbo that I can see.
Mind you, I'm not sure I'd recognise it so I took a couple of pics in case you might recognise anything I missed. There are 2 or 3 plastic multiplugs to the left of the turbo but they're all connected to something...
Mine must've been too early for that upgradeDo you know of any additional wiring that might make the upgrade viable, I wonder? Thanks for that info though - it would've made that 1499 conversion a 'piece of cake'...
TorqueHorse wrote:Hey just catching this thread, but this quoted part stood out...chrism wrote:So, it seems that to enhance fuel economy and reduce over-fuelling or partial-burning smell a 9930 or 1499 + O2 sensor upgrade would be the way to go - but neither are available now and probably won't be offered used, either(?)
The 1499 IS still available; just attached as part of a new ECU. I got one myself a few months ago. https://deroure.com/partinfo.asp?MAK=0& ... PBID=62084
The O2 sensors are available too from various sources. SJ has them it seems https://www.sjsportscars.com/parts-and- ... E6024S.htm, and you can look through old threads and find parts cross-references to others available on other sites too.
Good luck
