Rapid ticking noise behind manifold in service mode
Postby madbilly » Tue 03.07.2012, 21:55
Hiya,
I put the car in service mode to check fault codes and heard a rapid ticking noise coming from behind the intake manifold, disappeared when I removed the paperclip and returned when I reinserted it. Any ideas what it might be? Secondary throttle solenoid?
Also, I moved the throttle and there was a short of crunchy electrical noise, perhaps from the TPS?
Will
madbilly
Re: Rapid ticking noise behind manifold in service mode
Postby RayD » Thu 05.07.2012, 21:54
Will,
I’m sure it won’t be this simple but ...
Having never heard a sound on the occasion of putting the clip in, my first thought would be a bad connection on the clip.
Try a thicker one and see if waggling it about makes any difference.
Ray
RayD
Postby CalElan » Mon 08.08.2022, 01:32
Resurrecting this old thread.
I’m trying to resolve some issues with my car. There is a slight hunt at idle and car is stalling when coming to a junction.
Put the car in service mode to pull the codes and I noticed this same ticking noise coming from behind the plenum.
The rhythm seems to match the rev fluctuation.
Did anyone ever get to the bottom of this?
CalElan
Users browsing this forum: Apple [Bot] and 2 guests
