Mirror switch
Mirror switch
Postby LeedsMike » Thu 24.11.2022, 10:05
Looks like my electric mirror switch is starting to die. Drivers side randomly won’t adjust left/right.
SJ are saying they can no longer get the item.
Any suggestions on where to source a new one?
S2 #388
LeedsMike
Re: Mirror switch
Postby dapinky » Thu 24.11.2022, 11:46
Not sure about getting one new, but the switch can be replaced with one from a Series 1 Vauxhall Frontera (or Omega) switch.......https://www.ebay.co.uk/itm/394028223918
If you don't want the 'heating' function, then the Holden Comodore switch looks like it could be suitable, but I don't know if it is 'plug and play' or would need some wiring work...... https://www.ebay.co.uk/itm/304550125145
Re: Mirror switch
Postby LeedsMike » Thu 24.11.2022, 13:18
Thanks Dave.
The Omega one still doesn’t have the button to trigger the heating. It must hang off the rear heated screen in the Omega?
S2 #388
LeedsMike
Re: Mirror switch
Postby dapinky » Thu 24.11.2022, 15:25
Ah, good point about the screen heater!
I have to admit, my own switch stopped working many years ago, and is still on the list of things to look at when I get round to it - but as I don't use it in weather when a heater is required, and haven't needed to move the mirror position in the last 8 years, it isn't a priority.
Re: Mirror switch
Postby Tuga2112 » Sat 26.11.2022, 15:13
have you tried unplugging it and giving it a generous dose of contact cleaner at the terminals and plug back in ?
ive had many switches over the years that between that and simply undoing their interanls and cleaning was enough to fix
ultimately all switches are just mechanical connections and are usually designed so you can re-open them to clean any dust and re-assemble
Re: Mirror switch
Postby johnj » Sat 26.11.2022, 17:31
I had a problem with the mirror switch. The mirror only moved in one plane. It is possible to open the switch, but open carefully with the switch parallel to a clean surface as there are 3 small loose cones that the can fall out. I cleaned the insides with electrical contact spray, and everything now works as it should. As dapinky once the mirrors are in position you do not use the switch.
johnj
Re: Mirror switch
Postby esprit888 » Sun 27.11.2022, 20:45
Ummm, they are available, even used, but a little pricey :lol: :lol: :lol: :lol:
https://pkautoparts.com/04-lamborghini- ... a-pk009212
esprit888
Re: Mirror switch
Postby M100Brisbane » Mon 28.11.2022, 11:41
Down here in Oz, I bought a switch via eBay from a wrecker, described as coming from a Holden Astra TR. Looked perfect, had the heater switch and all.
Catch is that the plug gender is wrong - (male/female) so I haven't used it yet.
Wonder why GM did that?
Michael
Brisbane - Australia
Elan M100 S2
Europa S2
M100Brisbane
Re: Mirror switch
Postby LeedsMike » Sun 22.01.2023, 22:22
Tuga2112 wrote:have you tried unplugging it and giving it a generous dose of contact cleaner at the terminals and plug back in ?
Good advice. I will give this a go first before anything more drastic. Thanks!
S2 #388
LeedsMike
Re: Mirror switch
Postby andrewp » Mon 03.04.2023, 04:40
Many SAAB's use the exact Elan M100 mirror switch. For certain the SAAB 9-5 (early 2000's) will have the exact same yellow LED and mirror heater button.
If you can live without heated mirrors, then SAAB 9-3 (late 1990's), as well as about 20 GM or Saturn vehicles.
I have at least 20 spare power mirror switches sourced from discarded cars in self-serve auto wreckers.
andrewp
Re: Mirror switch
Postby Tuga2112 » Mon 03.04.2023, 09:58
andrewp wrote:Many SAAB's use the exact Elan M100 mirror switch. For certain the SAAB 9-5 (early 2000's) will have the exact same yellow LED and mirror heater button.
are the connections at the back the same ?
Re: Mirror switch
Postby andrewp » Sun 05.04.2026, 20:59
Yes, heated or not heated . . . all the GM and SAAB power mirror switches (at least here in North Ameica) have the same wiring connection as that used in my 1991 Elan M100. I have dozens of spares (likely 40?) as a lot of GM wrecked cars have donated their power mirrow switches to my Lotus drawer.
E-mail me (andrewp1989@hotmail.com) should you need one. You will have to pay for the shipping.
Andrew in Edmonton
andrewp
