New member
Re: New member
Postby Tuga2112 » Tue 04.04.2023, 08:32
White Elan Man wrote:Well, I finally had a full day on the car, I set out to remove both wheel liners and repair both headlamp motors. It soon started going wrong. On removing the nearside headlamp motor I noticed a screw and gasket was missing from the motor plate so I decided to open her right up.
No springs behind the brushes, l soon found one, it was crushed between the motor casing and ball bearing, the other one is MIA.
I took the advice of the repair kit and cut down a pen spring, luckily the kit had a couple of spare screws and the gasket I needed.
I metered it out then tried it on a motorcylce battery and all was good, re- installed and no joy. Traced it back to the 15amp fuse below the access panel behind the clocks, I reckon the brush leads had shorted on the casing previously
So one side is done, and looking forward to the easier side tomorrow and hopefully get to the bottom of the problems with the boost and tacho gauge’s
I must say that I thoroughly enjoyed myself
sounds like your about to start a project thread :P
we want pictures :D
Re: New member
Postby TorqueHorse » Tue 04.04.2023, 12:54
Exactly! That's how it always starts :)
Glad you had a fun on the car.
'91 FED M100 -rolling resto
Users browsing this forum: Apple [Bot] and 2 guests
