simonbuk wrote:Anybody interested ?!
TorqueHorse wrote:Hopefully you can find someone more local to you, but if not, and you can get me a plane ticket and a roof over my head, I'll do it
HJ2 wrote:I'm not in the south-east
dapinky wrote:HJ2 wrote:I'm not in the south-east
You're still closer than I am!
Saltire wrote:I commuted from LHR to Houston for work at one stage (although not on a daily basis), so it’s not out of the question![]()
"Have torquewrench; will travel"alan e wrote:
I live in Worthing so you can't get much closer then that.
while I'm playing travelling repairman there.Saltire wrote:simonbuk wrote:Anybody interested ?!
My chap is still around! (Although he’s a sailor, so will probably have swanned off to his boat at the slightest opportunity![]()
simonbuk wrote:Saltire wrote:simonbuk wrote:Anybody interested ?!
Thanks for your reply earlier - tried to respond but the website was throwing a tantrum on the private messages !!
Simon_P wrote:
Is this one complete engine or a head and a block and you think that you have the rest of the bits?
You don't say to what state you want it built up?
As Dave says - an experienced engine guy rather than an experienced Lotus engine guy. someone who will notice that: there is no regrind permissible on the crank, there are no graded bearings available and Turbo main bearings aren't available. Of course you could regrind the crank and use the bearings in the catalogue and that might work..... your engine builder did tell you that he drilled the extra hole in the mains for the Turbo piston cooling jets right? or does whoever's building it need to know enough to disassemble it and check. (the aftermarket bearings, although listed for the Turbo are N/A bearings with only 1 oil hole). Of course not everyone will agree and some will say it will be fine.simonbuk wrote:I know people talk about these engines being 'specialist' engines and being Lotus et al, but they very much look like a generic GM engine of the 90's so surely a competent mechanic should be able to bolt it together and add the ancillaries back on ? Would you really have to have an experienced Lotus guy to do it ?
Users browsing this forum: Google [Bot] and 6 guests
