So....how did the M.O.T go? (or overseas equivalent)
Re: So....how did the M.O.T go? (or overseas equivalent)
Postby Rice crispy » Mon 03.04.2023, 15:38
Dropped mine off for its service and MOT this morning. Had to clean the contacts for a front sidelight and indicator yesterday when I was doing some checks as it hasn't been used much this year so far. Did the front shocks and springs last year and a rear wheel bearing although my mechanic was adamant the bearing was ok. Fingers crossed
Rice crispy
Postby Rice crispy » Tue 04.04.2023, 13:28
She passed no advisories, must get her out more this year
Rice crispy
Postby Tuga2112 » Tue 04.04.2023, 14:09
Rice crispy wrote:She passed no advisories, must get her out more this year
yes you shoudl!!!
i took mine to the NELOC meetup just last night.
Postby TrevorB » Wed 10.05.2023, 13:05
'Merlot' back home after a successful MOT pass and no advisories. Excellent emissions result as well.
CO 0.37%
HC 55 ppm
All ready for the drive to Castle Coombe later this month.
:cheers:
Trevor
Wannabe Princess
Postby dapinky » Fri 19.05.2023, 13:35
Well, another lovely drive round the West Wales countryside (why use a garage that is too close to home to enjoy the drive out?) to the testing station.....
... everything has changed since my last visit (back in January with the VW).
They now have a new setup installed (which looks pretty much like the old system), except it now sends info directly to VOSA from the emissions and the brake rollers.... and a CCTV system to show the cars in the bay. The system doesn't completely observe the test procedure (but maybe that will happen in the future, who knows), but the computer can tell (if anyone is looking.... or maybe it's like an ANPR system?) which car is being tested.
As such, there is no way for a test to be completed in less than the prescribed time (which was used drinking tea!) to get more cars through the bay in a day. There is no way for the exhaust sniffer to be inserted in a different pipe (well, I suppose it isn't hard to insert a probe up the car on camera, and then insert another probe connected to the equipment into another car which is recording???) - brakes, however, can't be 'got round' in a similar manner.
Still, it isn't a problem to those of us who see road safety as more important than numbers on a piece of paper (brakes are pretty important - emissions not-so-much). I'd rather a car failed if it is a danger to me or anyone else, for the sake of a few hours work.
Anyway, the numbers for my car were okay (not as low as Trevor's but still good for a car with 138K miles on the clock)....
0.63% CO and 91ppm HC
Brakes, I can't remember, but well up to the required minimum (as expected seeing as I did the annual strip, clean & regrease of all 4 corners yesterday). I did notice that the rear steel pipes are looking a bit past their best, and Ray put them down as an advisory, so this afternoon will be spent fitting a set of braided hoses and new solid pipes.
Apart from that, no other issues, so all ready for Castle Combe next week.
Postby alan e » Mon 05.06.2023, 17:53
Passed today Good for one more year 3 advisories surface corrosion on brake pipes and slight play in both rear wheel bearings nothing to worry about re the bearings pleased about the readings CO 0.58% and HC 58 PPM so the old Lotus cars are saving the planet who needs electric cars.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby Steve A » Mon 05.06.2023, 19:35
alan e wrote:Passed today Good for one more year 3 advisories surface corrosion on brake pipes and slight play in both rear wheel bearings nothing to worry about re the bearings pleased about the readings CO 0.58% and HC 58 PPM so the old Lotus cars are saving the planet who needs electric cars.
I wonder how close our cars are to pass the emission levels for London :? :smt102
Postby Blaster » Mon 05.06.2023, 22:52
The problem is it is Nox that they look at 0.08gm/Km and the MOT does not measure it.
Tony
1990 Lotus Elan SE 2009 Triumph Daytona 675SE
2012 KTM Freeride 350 2008 VW T5 4-Motion camper.
1995 Defender 300TDi 2012 Ducati Hypermotard
2018 AC Nitro 200 and Dudek Solo wing
Blaster
Postby RonR » Thu 29.06.2023, 12:27
After a complete engine, front suspension and brake rebuild I was expecting one or two teething problems.
Took the car to the MOT on Monday and it passed with no advisories! :D So she's 'back on the road again'.
I'll be driving her like Miss Daisy for the first few hundred miles :(
Postby TrevorB » Thu 29.06.2023, 19:02
RonR wrote:After a complete engine, front suspension and brake rebuild I was expecting one or two teething problems.
Great news Ron, all the hardwork has been worthwhile. We will see you at some NKLG meetings very soon know doubt.
:clap: :clap:
Trevor and Merlot
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby dapinky » Fri 11.08.2023, 12:38
Well, a picture is worth 1000 words, so that is all you get!
Oh, okay, you can have a few words as well..... After a bit of work to recommission the car, I was pleased to not have a 'snag list' to work through - always possible when so much work has been done in one hit, and you can't always isolate a problem to a specific (recently worked-on) part.
The emissions were low (as expected) as it's running closed loop Everest, brakes all excellent and balanced, and the only point to note is that it feels like I have a square wheel.... so I do have something to investigate, but nowt to worry about.
Postby Jamie N » Tue 05.09.2023, 13:44
Passed today with no advisories, embarrased to say how many miles it's done in the last 5 years so I'm not gonna :D , making up for it this week though, it's scorching up here. ;-)
Monaco S2 #406
Jamie N
Seal God
Postby Tuga2112 » Mon 11.09.2023, 16:31
Jamie N wrote: embarrased to say how many miles it's done in the last 5 years so I'm not gonna :D
i shall be giving you plenty of abuse on that topic next time im in Fife :lol:
Postby gogo » Mon 11.09.2023, 21:35
passed today, croatian version of m.o.t and its kia elan
o2 is a bit bad
https://imgur.com/cAYQ0I0
https://imgur.com/ZBxrcEF
gogo
Postby Rambo » Tue 12.09.2023, 14:41
Jamie N wrote:Passed today with no advisories, embarrased to say how many miles it's done in the last 5 years so I'm not gonna :D , making up for it this week though, it's scorching up here. ;-)
Garage Queen !!
Postby Steve A » Mon 02.10.2023, 15:42
Passed today with no advisories :D even though I'd done over 400 miles more than last year :P
Postby woody » Tue 17.10.2023, 13:21
Passed today with no advisories : :-) but I had to have a cat fitted, and it took the tester a very long time to get the engine hot enough to pass the emissions test. The emissions tests are definately getting more stringent.
CO : 0.24% vol
HC : 65ppm
~ : 1.019
Woody
woody
Postby Fredjohn » Thu 19.10.2023, 15:51
Passed today, 3 v. minor advisories.
CO 0.47.
Still showing huge benefits of going closed loop (also with Everest chip)
Postby JethroGreenfinger » Sat 27.04.2024, 07:55
Just wanted to say thank you to anyone who has posted on this great forum, my car passed its first MOT since 2011 yesterday, I couldn't have done it without you lot :-)
JethroGreenfinger
Postby chrism » Sat 27.04.2024, 08:33
Cor, those wheels look good too :). Look like 17" MGRover hairpins? Easy to fit? Any wheelarch rubbing?
chrism
Return to General
