dapinky wrote:Good find, Joao - it isn't something which springs to mind as being a possible problem, as it is fairly rare!
dapinky wrote:Do you know if it is the caliper that is worn, or the sliders?
dapinky wrote:If you need them, I have calipers and sliders on the shelf (good used ones, and a pair of new ones)
dapinky wrote:I suspect this is a simple case of failure to check and maintain the OE brakes regularly (by a previous owner, not you!) - once they get a bit of rust in the sliders, it will act as an abrasive, and over time will wear away the metal - it will only get worse with use. Some of the wear can be eradicated with silicone grease, but worth keeping an eye on it.
Tuga2112 wrote: but while i was messing about with it i noticed that it still has the original heater valve... which is stuck solid in place.
i know the replacement is from a volvo, but i dont know which one, so i need to have a look at the wiki for that and order a replacement
Tuga2112 wrote:i found out now that its getting dark that most of the interior lights are not working. all the lights on the instrument clusters are fine (althoguht some bulbs were replaced as per youtube update) but the other backing lights around the dasboard (heater controls, switches etc) dont work... so upon a little check i found a note in the service bulletin that gives me a hint that explains why reading the wiring diagrams nothing made sense to me.
lotusflasherman wrote: The Bulletin also claimed it would 'reduce battery drain when parking with sidelights on' but that could be achieved by using the rheostat to turn off instrument lights anyway, so a load of b0llocks!
lotusflasherman wrote:Did you check the rheostat position to see if that cured your lights off condition?
Tuga2112 wrote:the electrical side of things is waiting for the winter to be resolved. as the car is running at the moment and doing the job of going from A to B just as one needs it to.
)Tuga2112 wrote:althought the car is running fine. theres an odd issue with the idle speed, its very fast but as soon as the car completely stops it drops considerably, althought its still a little high, the drop is very considerable, i need to investigate, I cannot hear any vacum leaks, but havent really put my head deep in the engine bay while running to have a close listen,
Users browsing this forum: No registered users and 35 guests
