No engine faults codes at present, have just logged an elan scan run which I hope maybe someone might be able to help with.
I found a similar thread whereby someone had virtually the same fault and so ive ordered a new CAS again
Rambo wrote:Have you done the paperclip/self diagnostic check?
If so, had you had a CAS fault, it would have shown up as error 41. Why do you think you need another expensive CAS? They are pretty bomb proof apart from o seals and becoming noisy.
KenS wrote:Has the static timing been set up while in Service mode (ref the WikiLEC)? Needs a LEC expert to interpet the log file, but to me it looks like the 'spark advance' may be indicating a base timing of around 10 degrees instead of the required 16 degrees. If the engine is retarded, this may explain why the 'knock count' is high/odd ? I am sure someone will come forward with a more confident appraisal of your log file!
Tuga2112 wrote:just another random idea... the TPS may be set incorrectly and the computer just never thinks your putting the foot down enouhg
KenS wrote:Tuga2112 wrote:just another random idea... the TPS may be set incorrectly and the computer just never thinks your putting the foot down enouhg
The log file for the TPS & engine RPM shows that the TPS sensor voltage doesn't reach the 4.0V that would be expected for full throttle, only attaining 2V and revs reaching 4000.
For reference an random example of a log file for a different car shows TPS reaching the 4.0V level and correspondingly the rpm achieves 6500.
So Joao may be correct? May be worth trying to devise a method of measuring the voltage at the TPS. There is some info in the Engine Management Manual Section EMK.4 page 38.
dapinky wrote:Probably connected to the above, because the numbers correlate..... but if you look at 'Throttle' as the Y axis, it only goes up to about 45% - which is about what we'd see with a 2V TPS signal....
.... so either there was no 'foot down' driving during this recording, possibly due to the fault, or it isn't set up right.
Both throttle and TPS are easy to see and set with Elanscan - just connect it with the ignition on and start talking.....
At rest, the throttle should read 0% and the TPS should read 0.4V........ slowly operate the throttle pedal and watch the numbers increase to 100% and 4.0V.
If it doesn't get to 100% it indicates either an obstruction to the pedal (thick mats?) or a badly adjusted cable - there should be a quite slack cable, but still able to reach 100% on the pedal...... if it doesn't then have an assistant under the bonnet open the throttle by hand whilst your foot is on the pedal, and see if it then goes to 100% (it should!) and if not, then there is a problem with the mechanism... however, I have never seen one where it requires anything other than a slight adjustment of the cable.
I certainly have never known a cable so slack that it would only give 45% throttle.
The TPS adjustment is by way of 2 M4 setscrews on the TPS into the housing - slacken the screws (or remove them and throw them away, replacing them with new stainless M4 ones!) rotate the TPS unit until it reads 0.4V at rest, tighten screws. Open and close throttle by hand to check it reads between 0.4 and 4.0 volts (it may take a while to get it right - mines took about 5 or 6 adjustments to get it to return to 0.4.... it seemed okay until I opened it fully, then returned to either 0.38 or 0.42..... but I got it in the end.
kevrob wrote:dapinky wrote:Probably connected to the above, because the numbers correlate..... but if you look at 'Throttle' as the Y axis, it only goes up to about 45% - which is about what we'd see with a 2V TPS signal....
There was no foot down driving only part throttle/// rechecked TPS and all good goes from .38 to 3.99
KenS wrote:Oh, back to square 1.
Once you get the idle set-up, I think the base timing needs resetting (follow the WikiLEC base timing procedure which sets the IAC), the current log file does look like its currently around 10 deg btdc but at that high idle.:
If still no luck its worth capturing a new Elanscan log file, with some full throttle periods which may show something odd at the higher throttle values.
