Boot light fix suggestions please.
Postby Pompeydave » Sun 14.01.2024, 15:17
At last, I've found part, and hopefully all of the electrical leak problems on my S2. The boot light was stuck on as the cam isn't pushing up against the switch enough. Anyone suggest how much I need to add height wise to it to get it to make and break? 1/2 an inch maybe?
Pompeydave
Re: Boot light fix suggestions please.
Postby Saltire » Mon 15.01.2024, 08:45
I had a similar issue with my S2 when I bought it. At first I thought the switch might be adjustable in and out, but it didn’t seem to be.
I used a short length of thick EPDM rubber stuck to the switch side of the actuating arm, put my phone in the boot recording on video mode, and added extra rubber thickness until I could see the light was going out when I shut the lid. Once I knew the thickness I needed, I made up a permanent pad from a piece of scrap aluminium, with a thin EPDM cushion, and glued this to the actuating arm.
Of course you could just pull the boot light wires - but be warned that one of them is also linked to the standard S2 alarm if you still have it, so watch out that you don’t exchange one problem for another :lol:
