siejai wrote: Maybe I'll throw a switch on the fuel pump relay if I can't figure it out.
siejai wrote: I don't think it had a delay with the ignition or anything,
siejai wrote:I believe it was just a timer to keep the engine running after shutting it off after running the car hard (?)
siejai wrote:but I'll probably need to trace out the ignition wiring to make sure it isn't connected to anything it shouldn't be.
siejai wrote:I just figured I'd post on here to see if anyone else had any ideas of something more simple that I might have overlooked. Hopefully it's not the alternator.
siejai wrote:Today I'm pretty sure the alternator died, or at least the rectifier portion, as I had some issues getting the car to start.
siejai wrote:So I'm going to change out the alternator and hopefully that fixes the ignition issue.
siejai wrote:Looks like I did order the wrong ignition switch, I got the non-airbag version. It definitely didn't cause the problem, but probably explains why the connectors didn't match up. I didn't change anything with the car before it started acting up, it was just sitting in a garage for 6 months (maybe 9).
siejai wrote:Tuga - I watched your videos on the alternator, do you think it's worth rebuilding the alternator and if so where did you get the parts?
My options look like buy from SJ Sportscars and pay a ton of shipping and get some kind of alternator that will work (I have no idea what sort they are reselling) for around $180, I can get a proper rebuilt alternator from somewhere else in the UK ($223.00), or I grab something local that works with 90-92 Isuzu Impulse/Stylus and Geo Storm for around $90 and hope it fits. Also there is one on eBay for $180, but it's just pulled out of a M100 not refurbished or anything.
looking at the wiring diagram on Saltair's post the ignition switch wire, coils and alternator are all on the same feed. So a fault in the wiring or alternator could cause that to remain energised. (This includes the ignition service which are connected).Tuga2112 wrote:the coil packs are directly feed from the ignition wire (comes from the ignition switch, (black) to a connector (white) and then splits to multiple lanes (including 3 white and 1 red)
the red one goes tot he coil packs. and without power there, you cannot physically get sparks.
not so sure about that Tuga, could an alternator fault that keeps the voltage up enough to run could also pull into down enough to not run?Tuga2112 wrote:but, as previously mentioned. your starting issue is NOT going to be directly related to the alternator.
Simon_P wrote:not so sure about that Tuga, could an alternator fault that keeps the voltage up enough to run could also pull into down enough to not run?Tuga2112 wrote:but, as previously mentioned. your starting issue is NOT going to be directly related to the alternator.
Simon_P wrote:looking at the wiring diagram on Saltair's post the ignition switch wire, coils and alternator are all on the same feed. So a fault in the wiring or alternator could cause that to remain energised. (This includes the ignition service which are connected).
So it should be straight forward to check this feed and isolate things until there's no voltage. Ie ignition off there should be no voltage in the wire, if there's voltage there's a fault.
Assuming you find voltage, disconnect the wire at the alternator - if the voltage is then zero the alternator is at fault.
Tuga2112 wrote:i gotta say i do enjoy the mental exercises that diagnosing Other People's electrical issues brings..
No idea if it is possible or how to test it, but I did see that the alternator is at the end of the line - so if there is voltage with the ignition off and disconnecting the alternator removes the voltage it is likely that the alternator is the cause - What do you think?Tuga2112 wrote:after re-reading the same wiring diagram from jonathan's second picture. I have came to your way of thinking
Simon_P wrote:Joao,
