chrism wrote:
Yep, like Simon_P I got the same old rubbish from usb EScan this morning using Matts' downloads
RonR wrote:Caveat: This might not be the only problem affecting ES, it's just the one I've found so far!
RonR wrote:So - it looks like a combination of a small bug in ES (which would never have been triggered when it was written) and the USB2 & USB3 drivers behaving differently that are causing us problems.
command> list
CNCA0 PortName=-
CNCB0 PortName=-change CNCA0 PortName=COM15
change CNCB0 PortName=COM16command> list
This is brilliant, I can't wait to try this...RonR wrote:Well done Matt, the script works a treat!
I tried it on Windows 10 22H2 with an ES cable on a USB3 port with the Latency timer set to 1ms and I didn't see any errors at all - It would never have worked without your script! Once I'd seen the data scrolling by in the console window I removed the display code so the script now runs silently on my Laptop - I've attached it here.
For those not Tech-Savvy - to stop the script click on the window it's running in and hit Ctrl-C.
Coincidentally I used Com0Com in my unsuccessful attempt to get a serial solution working over Bluetooth BLE, but I used Version 3 - I now wonder if it would have worked with version 2?
RonR wrote:Now if we could get our hands on the source code or patch the ES executable....
KenS wrote:Great work Matt, I have run your new Elanscan USB version on Win11 USB2 (I dont have USB3) with a FTDI wired interface and an ESP32 Classic/BR Bluetooth interface and they both run well. Its a big tick from me. Thanks.
Well impressed!!!
RonR wrote:Well done again, Matt![]()
I can confirm it also works with USB3 on Windows 10. Would someone like to try it on Windows 11 with USB3, just to be sure all bases are covered?
