carlotus wrote:Great feedback, I will have a look at the right front caliper today. I neglected to say, my m100 came with a brake upgrade kit. Subaru Legacy rotors with Saab 9-3 calipers. I guess this doesn’t matter as the principle is still the same.
Carl
lotustonybassplayer wrote:Just to add I had a severe pull to the left when braking. The culprit, rear diagonal brake due to the proportion valve being inoperative. Solution was to fit dpinky's adjustable valve mod. Which balanced the front and rear brakes.
carlotus wrote:While scratching my head this morning I discovered my left rear shock is bad. Right rear shock is stiff and left rear is going up and down way too much. I remembered the previous owner telling me the rear shocks were replaced recently and they’re adjustable. I made sure they’re adjusted similarly. I wonder if this could be causing my car to turn left under heavy braking
Again, I appreciate all the feedback
Carl
what is the theory Jaoa?Tuga2112 wrote:in theory yes, the simple solution is to set all shocks to maximum por minimum stiffness (i would suggest maximum) and retry. if the car doesn't pull you have finished your diagnostics. if it still does, you know have more work to do at the end.
Users browsing this forum: Bing [Bot] and 1 guest
