Alternator alternative
Postby M100TURBOFR » Fri 20.09.2024, 14:03
Hi
Have just finished taking out the alternator on a SE Turbo. What a job! Had to finally lower the exhaust and it just passed through the gap between the steering rack. I'll be getting it repaired but just wondered whether there are identical alternatives out there. Dave Pink - In your recent post on Trevor's O2 sensor problems you mentioned Remy 14971 from Rock Auto.
I enquired over here and nobody seems to recognize my DENSO reference 8970191300.
Thanks in advance
M100TURBOFR
Re: Alternator alternative
Postby dapinky » Fri 20.09.2024, 16:04
David,
Getting one in Europe (other than from a Lotus specialist) is going to be very dependent on how hard the person looks for a suitable cross reference - I don't know if they were ever used on a European market vehicle other than the Elan. Hence why I use Rock Auto (or other US suppliers) for a lot of my purchases - they nearly all have access to the parts information (even if they can't actually get the parts) as they are used in the Isuzu Impulse and GEO Storm (both of which sold in fairly strong numbers in the USA).
The Remy unit I bought (I have actually bought 2 of them) is listed for the Impulse, but isn't 100% identical to the unit fitted to the Elan (it is slightly larger, higher capacity and has a larger diameter pulley) - however, it is a straight swap (except changing to a longer drive belt makes the adjustment bolts land in a more easily accessible location).
