Robm100 wrote:What we're planning is to crack the head off by hand then use the engine crane we have to hold the head whilst we check around for any pipes/connectors we may have missed. For a 34 year old car it's surprising the amount of sensors there are.
Simon_P wrote: For preference I would remove the plenum and the inlet only six or so bolts and so much easier particularly on reassembly
Tuga2112 wrote:just a warning. this is just a couple of guesses. i dont have hands on experience on skimming heads, i have been lucky that both times i changed the gaskets in cars there was no damage to the heads
the suggestions are just my train of thought if i was in your position.
i dont know how your company does the skimming, but i cant see reason why a manually operated milling machine wouldnt be able to skim around the dowels ?
have you tried heat to remove the dowels ?
also can take very precise measurments of them and ask nicely someone wiuth a lathe or milling machine to make new ones
Tuga2112 wrote:heres my ignorance coming through.
isn't that a sleeve replacement scenario ?
as far as skimming the head. have you tried to use a nylon rust removal brush on a drill to clean the crap ?
onse its clean you can put a straight edge on it to find out if it warped or not.
something like this, they wont cut tghouth the metal but all the gunk, gasket remains and rust will come out. giving you a pretty good surface to check
https://www.amazon.com/Abrasive-Filamen ... B0CJJWZFP4
dapinky wrote:Joao, the dowels need to come out, otherwise the head can't be clamped down to hold it steady enough to prevent warp.... and it is done with a fly mill.
The dowels can be removed with a hammer and chisel, and are a common enough part that your recon guy should be able to source.
Have you looked at the Workshop Manual for info on head skimming? - it tells you how much material it is permissible to remove before the head becomes a large paperweight with no automotive use. It is worth printing off the relevant page(s) for your machinist, as it is easy to remove too much when trying to remove warp and taking it too low - the head actually accepts quite a large (comparatively) bow before it doesn't seal, so no need to go 100% flat.
As a 'future information' thing, I always use stamps to mark the outside of the head with the amount that has been removed - it may help me (or someone else) in the future to decide if the head can be skimmed again or not (or if it will need a MLS gasket).... mine simply says "15thou skim, 07/2007" or similar.
Users browsing this forum: NickVR6 and 3 guests
