Hullo to any O2 Sensor gurus out there.
Had a Code 13 fault a few days ago that seems now to be clear - I cleaned up the plug pins.
However, this meant that I had to think about the O2 sensor itself. I looks like a previous owner has spliced in a incorrect sensor - have a look at the photo.
Question is, should I swap in a correct one?
Elan scan data (idling, cold start on a warm spring day here in sunny Qld) is saying 128, what ever that means,
Time s 0.108000194
Prom id 1499
Faults 0
Time s 0.108000194
Engine run time s 12
Distance miles 0
TPS voltage V 0.4
Throttle % 0
Gear 0
Engine speed RPM 1225
Speed mph 0
Smoothed speed mph 0
Calc. speed mph 0
Acceleration g 0
Power horsepower 0
Barometer bar 1.00158
Boost bar 0
Manifold press (abs). bar 0.41583
Injector pulse width ms 2.311706543
Injector duty % 2.359867096
Spark advance ° 8.7890625
Coolant temp. °C 38
MAT °C 31.18
CO potentiometer/Oxygen sensor? V 2.156862745
Oxygen sensor (integrator)? 128
IAC position 44
Target idle RPM 1175
Battery volts V 14
Air/fuel ratio 13.9
DRP interval ms 24.44652
Voltage comp.? V 2.4
Wastegate duty cycle? % 0
Knock counter 0
Knock retard ° 0
Op. temp.- temp. °C 26
Coolant raw 73
