alternative for Elan M100 PS pump
Postby andrewp » Sat 27.07.2024, 03:40
Having personally rebuilt 5 or 6 Geo Storm, Isuzu Impulse, or Isuzu Stylus power steering pumps (all suitable alternatives to the Elan M100 pump), I have just found one new source:
One from a 2003 Chevrolet Tracker. Exceptionally small differences to the alloy pump body casting. Inner workings are identical. Low and high pressure fittings look wholly compatible. Rebuild kits are readily sourced (Rock Auto). Back plate is alloy and not cast iron (like my M100 original). Made by KYB of Japan.
Hope this helps someone.
andrewp
Re: alternative for Elan M100 PS pump
Postby perel » Fri 10.01.2025, 14:39
Interesting... Thanks
Do you have documentation of the pump
perel
Postby Fredjohn » Fri 10.01.2025, 15:14
Clarification please
Which Tracker V6 or 4cyl? They use different pas pumps.
Don't need one yet, but useful to know.
Postby andrewp » Sat 18.01.2025, 23:08
It was from the 4 cylinder Tracker.
AP in Edmonton, Alberta, Canada
andrewp
Return to Chassis & Steering
