Tuga2112 wrote:from the videos.
1 - we can clearly see the idle screw definitly does something (althouhg it seems to reach the full extent of screwing while having a idle that is too high)
2 - the last video. while unplugging the paperclip to me seems a 100% indication it must be something (not necessarily a sensor but most likely it will be) which is being defaulted in service mode, but in "full operation" mode is being set/read which causes the idle to jump drastically.
you need the little box that i have in my car... its just an ALDL cable. but its been wired differently from all others (another one of my little side projects) which allows to read the car and switch it from and to service mode while reading.
that last video has changed my perseption drastically. because there was clearly no outside change that could have allowed more air in, to make the revs change
im also fully convinced the IAC valve is not the problem.
a few thoughts i have at this moment are to make some alterations to your car and elanscan cable in order to be able to get a reading in service mode and another outside of service mode.
also. id be tempted to further investigate (probably ask peter) about what sensors are disabled by service mode.
given your extensive set of sensor replacements. i am expecting the issue to not be the sensor itself. but the wiring.
google/youtube "multimeter continuity test" and "multimeter resistance test" and try adding "car" or "automotive" in the search. if you can start checking the "quality" of each sensor's wiring you may find it.
if theres any sensors that are directly connected to ground nearby the sensor. i would be starting off with those.
chrism wrote:Erm, another thought roj...
Great videos responding so quickly to the dapinky advice offered but looking at the previous graphs I reckon you ought to have left the non-service mode running longer - ie for about 50s - before you might've expected to see some movement?
Btw is that IAC wiring m/plug easy to unplug? Let's wait to see if peteoddcar's sensor data can isolate anything but if my EScan plug is okayed I'd be happy to post it on to you...
chrism wrote:Not looking for an argument but I found these on another thread:-
How the secondaries work:
The secondaries are controlled by the ECU through a solenoid. The solenoid supplies a vacuum to an actuator which closes the secondary throttle against spring pressure at engine speeds below 4,700 rpm and/or at low drive speed. Closing the secondaries improves the low speed drivability and the idle.
I know little-or-nothing about sec throttles but these snippets infer that they're normally closed and open up at full chat? Perhaps someone with more 'know' can advise tho'.
dapinky wrote:Well, from the videos, it appears to me that as it runs fine with the IAC valve blocked off, it HAS to be something to do with that.
chrism wrote:Perhaps we need VAR...
I agree with Ken that the ecu +wiring seem to be 'working' (okay, after a fashion...)
ps so the bleed screw should be adjusted in 'service' mode rather than 'non-service' mode'?
TorqueHorse wrote:dapinky wrote:Well, from the videos, it appears to me that as it runs fine with the IAC valve blocked off, it HAS to be something to do with that.
Sorry I haven't been keeping up with this thread, as this is exactly where my head is as well!!
If you close off the IAC port, and suddenly the engine runs fine...ding ding ding I think you have found the problem area. Too much air is getting into the system, and it is getting in from that take-off to the IAC. And the only thing that can change the amount of air getting in via that passageway is the IAC pintle (double check my logic, but if it was getting in somewhere before or after the pintle, then putting your thumb over the take-off wouldn't change the idle).
So, trying to do process of elimination:
Is the ECU telling the pintle to be in the wrong place by mistake?
(i.e., a faulty sensor input upstream)
Maybe, but probably not because (I think) we see from elanscan that all the upstream readings are where they should be. And you can see in your scans that the IAC counts change while the engine runs. And because in your latest video in service mode, the pintle is being told, and trying, to fully extend.
Is the ECU telling the pintle to be in the right place, but the (correct)signal isn't getting to the IAC?
(i.e. faulty wiring)
Again, probably not because you see the pintle extending when you turn the engine on, so a signal is getting to the IAC
Is the IAC actually doing what the ECU is telling it to do?
Maybe. Seeing it fully extend in service mode makes me think it is doing what its being told. I am on my third IAC valve though where a "new" one didn't work for me.![]()
Is there something physically wrong with the pintle or the receiving area, so that even given the right signal, and fully extending, it still isn't able to properly moderate the air coming down that take-off pipe?
Maybe?? I can't see an o-ring in your videos of the IAC tests. Are you sure there isn't an old o-ring, or other obstruction in the intake manifold that is preventing the pintle from making a good seal when trying to cut-off that air flow? Also, I think it is a pretty tight fit to get the IAC valve to seat well in there. And getting access to those screws to secure it in place is a nightmare. Is it possible it just wasn't all the way in?
Sorry, I'm struggling too to make sense of what you've learned and tested so far.
