by bxs » Thu 04.09.2025, 19:51
Subject: Rear turn signal light bulbs
I note that the two rear L&R turn signal light bulbs are dual filament type 1057s. The official Owner's Handbook states that are 12v 21/5 meaning 21 watts & 5 watts. When the turn signal is activated only one element light flashes.
So why are there two filaments in these bulbs I ask?
bxs
by TorqueHorse » Thu 04.09.2025, 22:24
I can't remember exactly, but I think since it is both a Tail and Turn light, it will have different brightness depending on if your lights are on and if you are applying the brake?
I remember backing up to a dark glass storefront one night and trying every possible combination of lights while looking at the reflection. There is quite a lot going on back there
by bxs » Fri 05.09.2025, 16:16
Thanks @TorqueHorse ... You are correct about that ... and yes the two filaments are for side running light 5 watts, and 21 watt for the turn signal.
bxs
by Tuga2112 » Sat 06.09.2025, 16:21
do you guys have red turn lights ?
in the UK dual filament bulbs are used for sidelights and brake. single 5w being the sidelight and the 20w filament used when braking.
Users browsing this forum: Bing [Bot] and 3 guests
