by AJSGSE1990 » Sun 22.02.2026, 11:08
Took my recent purchase for a little drive to start planning out works. Outside temp was about 12 degrees and the car was fully warmed up and sitting just above what looks like 90. Within a few miles of country roads, the temperature dropped to cold, see image. Before I start looking to change the bypass valve I just wanted to check if this is normal for this car design.
Thank you.
AJSGSE1990
- Tinkerer
by chrism » Sun 22.02.2026, 11:40
AJSGSE1990, there's a lot on LEC that will support your temp gauge pic as being 'normal' when you're up to normal running temperature.
Here's a recent thread that addresses our 'overheating concern stresses'...'ElanScan' gives much better inside info on engine temp. data than this non-linear indicator/'temp gauge':-
viewtopic.php?f=134&t=30441
chrism
by AJSGSE1990 » Thu 26.02.2026, 20:32
chrism wrote:AJSGSE1990, there's a lot on LEC that will support your temp gauge pic as being 'normal' when you're up to normal running temperature.
I have not yet looked at Elanscan, I have a current project which I am 4 months late on and have missed the season opener test day. Pretty upsetting. Having resolved the cooling issues on two Italian cars I am not too scared! I just need to stop myself from rewiring the engine to a MaxxECU! or worse, Motec.
Andrew.
AJSGSE1990
- Tinkerer
Return to Heating and Cooling
Users browsing this forum: Google [Bot] and 6 guests
