Rear Brake Upgrade
Rear Brake Upgrade
Postby Jamie N » Wed 25.06.2025, 10:26
I have a couple of sets of the Type R / S brake kits if anyone is looking to upgrade. Everything ready to fit, no modifications just bolt them on. Very easy to service and spare parts if ever needed will be available for a long time to come. Can fit for you free if you can come to Fife!. Kit comes with everything needed, hoses, pads, brackets, bolts, and me as your online mentor if you need any advice when fitting :D .
Monaco S2 #406
Jamie N
Seal God
Re: Rear Brake Upgrade
Postby engtec » Sat 28.06.2025, 21:10
Hi Jamie
I would like to buy a set please.
Can you PM me or do you prefer to email me?
Kind Regards
Rich
engtec
Postby engtec » Sat 28.06.2025, 21:13
Hi Jamie
Kind Regards
Rich
engtec
Postby engtec » Tue 22.07.2025, 19:42
Thanks Jamie for a great kit :clap:
It was straightforward to fit and is a great improvement on the original setup.
All was spot on after I deglazed my original rear discs to enable the new pads to bed in properly.
Rich - engtec
91 M100 Elan SE
engtec
Postby engtec » Sun 27.07.2025, 22:12
Thanks for the kit Jamie.
It was easy to fit and my handbrake woes are now a thing of the past!
If anyone else goes for this upgrade and you are using your old discs make sure they are deglazed/roughed over to enable the new pads to bed in proper. I used a flap wheel in my angle grinder. I didn't initially.... schoolboy error :bonk:
Rich - engtec
91 M100 Elan SE
engtec
Postby NoahR » Sun 12.10.2025, 12:03
Jamie, are you able to repost the photos by any chance? I'm in the UK, but the pictures just show 'not viewable in your region'. Or I can PM you my email?
Thanks.
NoahR
Postby robertverhey » Wed 18.02.2026, 00:46
Jamie N wrote:I have a couple of sets of the Type R / S brake kits if anyone is looking to upgrade. Everything ready to fit, no modifications just bolt them on. Very easy to service and spare parts if ever needed will be available for a long time to come. Can fit for you free if you can come to Fife!. Kit comes with everything needed, hoses, pads, brackets, bolts, and me as your online mentor if you need any advice when fitting :D . £240 posted to anywhere in UK.
Hi Jamie interested to know what make and model caliper these are based on. Robert
robertverhey
Postby Jamie N » Wed 18.02.2026, 20:05
These are derived from a Honda Civic (FN2) Type R Robert, you can't just get a set and fit them to the Elan though, you need to fabricate the brackets and work out exactly the dimensions
and where to drill them, you also need a cable bracket from a Peugeot rather than the Honda one as it's a better fit for the Elan cable.
If you would rather take the simple route there are 2 sets here ready to fit with everything required, calipers, carriers, brackets, every bolt and a set of pads, just bolt them up and bleed the brakes,
you then have a fantastic handbrake that will be well over the required MOT percentage, and no problem sourcing parts if you ever need them. 190 Posted anywhere in UK or come to Fife and I'll fit them
for you.
Monaco S2 #406
Jamie N
Seal God
Postby Simon_H » Fri 20.02.2026, 14:05
Hi Jamie. I’ve just dropped you an email for one of these sets if they haven’t already been snapped up. Cheers Simon
Simon_H
Postby Rambo » Sun 22.02.2026, 07:12
Hi Jamie.
Rambo calling Rawshyte :lol:
Can you reserve the other set for JimB ? (Muley) please. He is currently in Kiwiland and locked out of LEC. I'll send you a PM with his message and we can hopefully sort out something for his return.
Slàinte, Mark.
Postby muley » Sun 22.02.2026, 19:40
Jamie
You have a PM.
Rgds
Postby Jamie N » Sun 22.02.2026, 19:52
Reply sent.
Monaco S2 #406
Jamie N
Seal God
Postby Jamie N » Tue 24.02.2026, 10:48
Just to add I also have a couple of pairs of these modern Bosch calipers if anyone is after super sharp front brakes for very little outlay. Again they require no mods to the car, simply bolt them on. Very easy
to service / change pads, remove one 13mm bolt and swing the caliper up and thats it. Grease the sliders once a year and these will last the lifetime of the car. Comes with everything including flexis and pads.
They have a massive amount of pad in contact with the disc as you can see in the picture, I have these on my own S2 and the difference from the old OEM brakes is astonishing, virtually as sharp as any other upgrade costing a fortune more.
By far the cheapest way to upgrade your front brakes. 180 the pair and I'll fit them for you, or post.
Monaco S2 #406
Jamie N
Seal God
Postby muley » Fri 27.02.2026, 02:37
Hi Jamie
Hello again.
You have another PM.
No prizes for guessing what it says...
Postby Jamie N » Sat 28.02.2026, 10:46
No problem Jim. :wink:
That's all the brakes now taken folks but if anyone wants a set in the future just send me a message.
Monaco S2 #406
Jamie N
Seal God
Postby Dtjonesy » Tue 21.04.2026, 15:11
HI Jamie
I have PM'd you regarding rear brake upgrade.
Hopefully you will have more stock soon
thanks for the great work
Dtjonesy
Postby L8apex » Tue 09.06.2026, 09:22
I am very much interested in getting a rear brake kit for my 91 Elan. Please let me know if the kits become available.
I live in the USA.
Thank You
Mark Hains
1991 red Elan SE
1969 S4 Elan SE coupe
2012 Fiat 500 Abarth
2007 Kubota B21 tractor with backhoe
Yes I know it's a tractor but it's a dam fine tractor
L8apex
Postby Monkeyzak » Fri 17.07.2026, 13:45
Are these kits still available? I am not too far away from you.
Derek
Monkeyzak
Postby Jamie N » Sat 18.07.2026, 09:10
Tried to send you a PM Zak but it keeps saying submitted form was invalid, tried deleting inbox and sent messages as they were full, but they wont delete either, site is also logging me out immediately
unless I tick the log me in automatically box.
Any ideas Dave? :D
Monaco S2 #406
Jamie N
Seal God
Postby dapinky » Sat 18.07.2026, 09:15
Jamie N wrote:Tried to send you a PM Zak but it keeps saying submitted form was invalid, tried deleting inbox and sent messages as they were full, but they wont delete either, site is also logging me out immediately
Any ideas Dave? :D
Not really - but I'll pass it on to Geoff who has a better idea than I do of the technical workings of the site (I only do the stuff that needs doing until it breaks, then I have to disturb his holidays!)
Edit:- I've sent him the link to this post so he can look at it.
Return to Elan Products for Sale (New Products for Sale)
Users browsing this forum: No registered users and 16 guests
