Tuga2112 wrote:is the idea to allow a broader range of wheels to the car while keeping the same geometry ? or something else?
chrism wrote:ps a third centre bore number of 56.6mm - others have mentioned 'dremmeling' the centre bores...
pps I now see your preference for that make of spacer, but on first inspection they're 30mm size. Do they do your 5mm/10mm/20mm options?
dapinky wrote:Spacers will tend to make the offset worse not better.....
dapinky wrote:IThe wheel without a spacer certainly looks better, and fills the arches nicely, but I can't see any advantage in fitting a spacer, and there are far more negatives than positives involved in doing so.
chrism wrote:So, no added spacers needed...perhaps a bit of bore dremmeling tho'.
chrism wrote:(I'm assuming it's correct since all the other stuff seems to be...can anyone confirm?)
