Checking through several of the last week or so plots also shows the point where the initial O2 sensor voltage collapses (at 35degC coolant temp) is consistant with the idle being slowly reduced and crossing the 1200rpm point and that point also corresponds to the IAC being in a very similar position around 42-46 counts (but this is where the ECU believes it has placed it, maybe not actual). I suppose the IAC is programmed to slowly walk down in relation to the coolant temperature, hence all 3, coolant temp, rpm and IAC position are all tightly linked. Is there something special about 1200rpm? Could the IAC be skipping counts around count 44? But cannot think of a reason for the mixture to go lean, if anything would think the revs would change or hunt.
