YHO chronicles
Re: YHO chronicles
Postby Tuga2112 » Mon 12.10.2026, 14:09
muley wrote:
Tuga2112 wrote:a generic pump works. mine set me back a whopping 15 quid during the lockdown.
still running strong after 5-6 years
Like https://www.amazon.co.uk/JUUDDENPARTS-G ... iewsAnchor
maybe? Thanks for the info
255 LHP (litres per hour) is what mine does. so, that should be similar. the pictures do look like the same.. but then again i am not sure if theres much variance in their appearence. i only seen them out of the fiat, celica (replacement from rockauto) and elan., and the 4 different ones looked all the same to me
the fuel pressure its supposed to sustain is also relevant to the stats. but i cant get the details about mine anymore. its been too long and the ebay listing is gone.
Re: YHO chronicles
Postby muley » Mon 12.10.2026, 22:00
Thanks Joao
Re: YHO chronicles
Postby muley » Mon 12.10.2026, 23:04
Job #1
Replace fuel pump. I've been hitting the tank ring with bigger
and bigger hammers, to no avail.
I am going to make a tool for this job ...
Re: YHO chronicles
Postby dapinky » Tue 13.10.2026, 08:52
As they say in Germany "no smacken der gaztank"...... I know it seems like a good idea to use a hammer and drift, but it can lead to cracking of the plastic round the rim, which isn't good!
I have done it that way, until I was advised of the perils, and since then I have used a toolmakers' clamp to grip the ring :shock:
I did make up a simple tool from 3 bits of dowel, a circle of plywood drilled in 3 places to poke the dowel through, and then used a large cable tie to pull the dowels into the ridges in the ring - but I lost it when I last needed to change the tank.
Re: YHO chronicles
Postby Fredjohn » Tue 13.10.2026, 09:29
Jim, try some very gentle heat from a hair dryer. Might be just enough to loosen the threads.
Re: YHO chronicles
Postby Tuga2112 » Tue 13.10.2026, 09:35
a bycicle inner tube may also work. using it in a similar manner as the oil filter tools work
Re: YHO chronicles
Postby muley » Tue 13.10.2026, 10:37
Thanks for the tips.
I'll be on it soon
