Exhaust rich smell
Exhaust rich smell
Postby pte123 » Sun 01.11.2026, 19:03
Hi All,
Just looking for some help troubleshooting. The exhaust is very sooty and it smells really rich. Does anyone have any thoughts on where I should start with troubleshooting?
I do have access to Elanscan. The idle seems okay and there's no check engine light on the dash.
Much appreciated! Phil
pte123
Re: Exhaust rich smell
Postby dapinky » Sun 01.11.2026, 19:17
My first thought is to see what Elanscan is saying the coolant temperature is.......
...... this sounds like a typical 'overfueling' situation, which is often brought about by the ECU thinking that the car is running much colder than it actually is, so throws extra petrol into the system.
If it is giving a low reading, the CTS probably needs changing, which is a fairly quick and easy thing to do, with aftermarket parts which can be purchased cheaply (under £20).
Postby pte123 » Mon 02.11.2026, 17:08
thanks Dave. Any idea where i would source one of those?
pte123
Postby dapinky » Mon 02.11.2026, 20:53
pte123 wrote:thanks Dave. Any idea where i would source one of those?
These are the ones I use - Standard Motor Parts TX3 - https://www.ebay.co.uk/itm/188934394393
Lots of cross-reference numbers listed on the advert if you wanted to try and source one from a local motor factor.
Postby pte123 » Mon 02.11.2026, 21:32
Thanks Dave, I found one on Amazon here in the US. Best, Phil.
pte123
