And yes, you're not alone in falling foul of those 'dinosaur' rear brakes. Jamie does a Honda type-R rear caliper upgrade - and the prospect of handbrake fail is now no longer an issue either...
Always good to get feedback too.
RonR wrote:Noah,
I'll PM you with more info & details.
CAS: In the M100's distributor-less ignition system the Cam Angle Sensor (CAS) sits on the end of the exhaust cam and sends signals to the ECU as the cam rotates. The ECU then decides when to fire the coils and how much fuel to inject. The timing's set by putting the ECU into service mode and rotating the CAS until the engine fires at 16 degrees BTDC.
BTW You don't need to set the CO Pot if you're Closed Loop, S2s don't even have one fitted.
Return to Elan Products for Sale (New Products for Sale)
