LOTUS ELAN WHEELS???POST YOUR WHEELS!
Postby hamleto » Sat 29.01.2005, 13:00
Hi boy,<br>I can put the  16'' elis wheels to my ELAN????<br><br>Post any photos,please!<br><br>Bye Bye ;)
hamleto
Re: Lotus Elise wheels to LOTUS ELAN???
Postby Sy V » Sat 29.01.2005, 13:17
Hamleto<br><br>I believe this is impossible (not advisable) because the off set is different.
LEC Godfather
Postby hamleto » Sat 29.01.2005, 15:04
[quote author=Sy link=board=wheels;num=1107000016;start=0#1 date=01/29/05 at 04:17:56]Hamleto<br><br>I believe this is impossible (not advisable) because the off set is different.[/quote]<br><br> :'( :'( :'( :'(<br><br>
hamleto
Postby hamleto » Sat 29.01.2005, 15:07
What wheels  I can buy for my elan???<br><br>Today I see a ELAN S2 with 16'' MILLE MIGLIA wheels.<br><br>Tank You<br><br><br>P.S<br><br>What'are the S1 /S2 difference??
hamleto
Postby delta » Sun 30.01.2005, 12:40
I still have a set Compomotive for sale. see this.:<br>http://www.lotuselancentral.com/cgi-bin/yabb/YaBB.cgi?board=salepart;action=display;num=1101830825<br><br>Send me an E-mail if interested.<br>Delta
delta
Postby hamleto » Sun 30.01.2005, 13:31
Image<br><br>My wheels have 4bolt,i see elan with wheels at 5bolt,what I put this wheels??? ???
hamleto
Re: LOTUS ELAN WHEELS???
Postby Sy V » Sun 30.01.2005, 19:41
Forget it...unless you want a major fuckaboutbeyondbeliefjob!<br>
LEC Godfather
Postby hamleto » Sun 30.01.2005, 20:51
[quote author=Sy link=board=wheels;num=1107000016;start=0#6 date=01/30/05 at 10:41:01]Forget it...unless you want a major fuckaboutbeyondbeliefjob!<br>[/quote]<br><br>Yes,i forget it :'(<br>Now I search 4bolt wheels,help me please.<br>Tank You
hamleto
Re: LOTUS ELAN WHEELS???POST YOUR WHEELS!
Postby Sy V » Mon 31.01.2005, 09:12
Hamleto<br><br>I'm not very good with memorising figures but the ideal wheel should have 4x100mm PCD and an offset of **mm?<br><br>Help required for this figure...is it 60 guys?<br><br>Yep it appears to be +60mm...<br><br>http://www.lotuselancentral.com/cgi-bin/yabb/YaBB.cgi?board=wheels;action=display;num=1071491569;start=44#44<br>
LEC Godfather
Postby stevo » Mon 31.01.2005, 10:19
60mm is on the oe wheel, but 50-40mm will do.
stevo
Postby hamleto » Mon 31.01.2005, 12:01
Great wheels STEVO ;)model??<br><br>I see MASITALY wheels,beatifoul,but I dont found its in ITALY!!!There isn't a website??<br><br>I have new tires,and I serch 15" wheels to get agressive loke to my elan ;)<br>
hamleto
Postby stevo » Mon 31.01.2005, 13:33
stevo
Postby Sy V » Mon 31.01.2005, 13:43
MASITALY seem to have gone out of favour here in the UK.<br>Apparently, there may be some centre bore implications to consider too.<br><br>Anyone know of our centre bore size?
LEC Godfather
Postby stevo » Mon 31.01.2005, 13:50
45mm rings a bell but dont quote me.
stevo
Postby Scott J » Mon 31.01.2005, 15:21
Hamleto,<br><br>Speedline do a wheel very similar to the Elise which comes with 50mm offset and fits Elan.   Wheel available in silver, gold, or white.<br><br>Think Speedline is Italian company so you should be able to find them.
Scott J
The prodigal son
Postby ab2cv » Mon 31.01.2005, 17:11
[quote author=hamleto link=board=wheels;num=1107000016;start=0#10 date=01/31/05 at 03:01:18]<br>I see MASITALY wheels,beatifoul,but I dont found its in ITALY!!!There isn't a website??<br>[/quote]<br>These guys are a uk stockist for MAS Italy<br>http://www.wheel-base.co.uk/site/<br><br>Scott, are the Speedlines you're thinking of the Alessio II's? I know those ones are very popular with the Vauxhall Nova/Corsa community as they come with a 49mm offset.<br>
Yellow Esprit GT3
ab2cv
Postby Scott J » Mon 31.01.2005, 17:36
Alan,<br><br>I have 5 spoke Speedlines.  I once saw a max powered Calibra with the identical wheels.   :-[    :'(    :'( <br><br>They seem to have a wide range compatible with Vauxhall/Elan hubs.
Scott J
The prodigal son
Postby Monty » Mon 31.01.2005, 17:41
[quote author=stevo link=board=wheels;num=1107000016;start=0#13 date=01/31/05 at 04:50:42]45mm rings a bell but dont quote me.[/quote]<br><br>I had to buy a hub ring as my wheels have a recess and one was missing and it had 56.5mm on it  ??? If i remember i`ll have a measure when i take the wheel of for a bleed.<br><br>Oh that wheel base is only 10mins from me  ;D
Postby Scott J » Mon 31.01.2005, 17:49
Alan,<br><br>my wheels are an older version of 2110.<br><br>The 2109c Safari, is the wheels i am after, 8 spoke design similar to Elise & BMW.   Available in JPS Gold.<br><br>speedlinecorse.co.uk<br><br>Their site quotes "Safari is highly popular with the hot hatch brigade"   Oh dear.   :-[    :-[
Scott J
The prodigal son
Postby Grandad » Mon 31.01.2005, 20:35
Hi Hamleto,<br>I have OZ Racing Super 'T's' on my SE. Size7.5in x 16in<br>100mm Stud centre diameter,45mm Offset.<br>One minor difference is that I now run on 195 x 40 x 16in tyres ( oem 205 x 45 x 15in ) but nothing catches<br>anywhere and handling does not seem to suffer.<br>Pete (aka Grandad)
Grandad
Return to Wheels and Tyres
Users browsing this forum: Google [Bot] and 4 guests
