Ok car is an S2 with precat still in but a 2.25" from there back with no main cat. Has a k&n and a bailey recirc dump valve. Last week i fitted an everest chip and all seemed fine if not quite as great as i was expecting. I sent Alan my logs and he confirmed my suspicions that i was well down on power, he reckons as much as 50bhp ! Since then i've put in new plugs, redone the timing which was out by about 4 or 5 degrees and today messed about with the dump valve, i disconnected the vacuum line to stop it dumping but still low power ? I know the precat may be restricting optimal bhp but i'm getting about 150 tops with an everest ! thats down on stock
