Seat belt stalk.
Seat belt stalk.
Postby John Kay » Mon 19.09.2005, 13:18
Does anyone know where i can get a seat belt stalk for a elan se turbo (J reg)... I've been trying for months now, i even had to take out the passenger seat to pass the mot! I have to pass my (the drivers) seat belt through the passengers at the mo any its not idea by any means!Help please!! The drivers stalk is also on the way out!
John Kay
Postby muley » Mon 19.09.2005, 13:53
I did get one from an OEM supplier - it was slightly shorter and needed a slight bend introduced into it but it was otherwise perfect. I'll try to dig out the info/remember where I bought it.
Jim B
seat belt stalk
Postby John Kay » Mon 19.09.2005, 14:24
Jim B,
If you could mate i would really appreciate it.....and so would my girlfriend as she's the one in the most danger!! I've had a real nightmare with this prob.
John Kay
Postby muley » Mon 19.09.2005, 15:53
John,
Bingo! Took a bit of time because I gave the receipt away with the car when I sold it. Anyway, what you should do is contact Quickfit Seat Belt Services 0208 206 0101. They will give you a fax number to fax a tracing of the seat belt tongue so they can match it. Tell them the length overall or from the mounting hole to the end (I can't remember which) and they'll tell you which one you need. It was about 16 pounds if I recall correctly.
Usual disclaimers
Jim B a.k.a. muley
(If you're successful, please post the part number for further reference - Chers)
Postby Monty » Mon 19.09.2005, 16:03
John,
U talking about where the seat belt clips into? I`ve got a pair still in pinky1 PM me if u`r interested.
Postby Doug » Mon 19.09.2005, 16:23
Mark A replaced his with a stalk from an Infinity (Nissan) I30 and said it is almost identical . . . don't know if you have that model type over there but just an FYI
Return to Interior
