Replacement lamp for instrument cluster
Postby DeanG » Thu 29.09.2005, 22:36
Where can I get a replacement for Lotus part number 100N6013 “Lamp & Holder (Green 12v 2w)? I can’t see the some of the tachometer and speedometer at night. The bulb looks to be a standard grain of wheat lamp soldered into a green injected molded plastic housing that has fixing ears and contacts. I don’t want to get into unsoldering the lamp then soldering the replacement. Dave Bean Engineering is out of them. Does anyone know what other North American cars use the bulbs?
DeanG
Postby Doug » Fri 30.09.2005, 01:28
since the dash is a GM part, I'd bet you could get the bulbs from a GM dealer. I've heard maybe camaro dash? I took a picture of one once to document it--I have some extras SOMEWHERE???
they are light green molded base with little bumps/wings that push in and then twist
if you remove the oval dash cover you can reach back there with your little hands and pop one out--then bring it to the auto parts store or GM dealer and see if they have a bin of em somewhere . . .
