One big "to do" in the future is lighter wheels
Dave M wrote:Yes, I still have the clips, thank you!!! My Kumho V700s seem awful heavy, too. More reason to get better wheels.
I thought of removing the top, but it goes back to the daily driver thing. If I'm at work and a storm rolls in...
Brian_MDB wrote:Dave M wrote:Yes, I still have the clips, thank you!!! My Kumho V700s seem awful heavy, too. More reason to get better wheels.
Maybe a lightweight hood cover with roll hoops, windblocker, bubbles etc to which fits an Elise type fabric cover or stowable carbon panels...
davidjt wrote:Is your flywheel the Fidanza model in the proposed group buy?
Brian_MDB wrote:Aluminum/ steel adjustable Camshaft Pulleys?
TheBard wrote:Hmmm, lights like this?
Brian_MDB wrote:If you're going to retain the stock pop-up headlamps it may be worth lightening or re-making the steel pod brackets and linkages etc, with aluminum or carbon ones? Same maybe applies for the brackets and bolts around the hood (bonnet) release?
The bolts holding the clamshell are hefty looking steel items sat on some big steel washers...the washers could be replaced with some nice countersunk anodized aluminum items(I have a supply for these...) and possibly the bolts too although I'm not sure if they do double duty holding something else besides the bodywork
The oil / air separator sits on a steel bracket and the cover is black painted steel , these could be aluminum/carbon/plastic using lighter fasteners, there may even be a lighter alternate assembly available...?
picture elf wrote:Brian_MDB wrote:Aluminum/ steel adjustable Camshaft Pulleys?
Bingo. I should check with the Isuzu guys to see if someone has an extra set lying around to use as a guide to have some made. I've got a client with a Mini Mill in his garage...
(oops...posted under the "other" ID while I was in posting a few pics...)
Users browsing this forum: Bing [Bot] and 3 guests
