LotusM100 wrote:Here is my question to you, what is the correct answer, can you bump the compression up a little to give your motor a little more to overcome any turbo lag?
Turbocharger wrote:More Turbos being looked at. I have started looking deeper into the Turbo selection process and may have found the best compromise. In total I looked at 5 different Turbos and one seems to fit the bill the best for packaging and power. It's the GT2560R which is good for between 200-280 HP and looks real good in the 265-270 Hp range which should be good enough (downgrading my 300-320 HP ambitions for better response). Best of all it will bolt up to my adapter and the compressor will point down like the stock setup out of the box, making that part of the plumbing easy. The turnine housing is Ni resist, the turbine wheel is Inconnel, turbine trim is 60 and A/R is .64, compressor trim is 62 and A/R is .60. Problem is I don't have a Turbo to test fit and I'm going off the drawings which is good enough. A Turbo is on order for me to test fit and as soon as I have it I'll take pictures. I can still go ahead with the downpipe though as the turbine housing configuration is the same and won't change between any GT25 or GT28 frame size.
,Russ
(stock can achieve 220-230BHP
Turbocharger wrote:(stock can achieve 220-230BHP
Brian_MDB wrote:My stock BHP comment was based upon LEC reports not personal experience.
Less lag and more power...I'm speculating that the +15 years of potential development time elapsed since our IHI unit was designed would enable us to achieve both...
