What about a rough price on this turbo unit?
Well, I guess that would depend on a few things. I did a guesstimate on all the parts required which would include: Turbo, downpipe, compressor inlet adaptor, compressor outlet adapter, gaskets, oil fittings and lines, water fittings and lines, studs, nuts, washers, bolts, silicone hoses for the compressor and filter and charge cooler, and new charge cooler. In other words everything except a new exhaust and engine management and came up with around $1600-$1800. Now that's as close as I could come based on guessing on some costs. Cost of the adapter, downpipe, and charge cooler depend on material and fabrication costs.
My only obstacles right now are the cost and fabrication of the downpipe and the charge cooler. I have a meeting this afternoon to discuss once and for all if the charge cooler will become a reality. What has to be done is a PO must be issued to our prototype shop from aftermarket. Aftermarket has already received a PO from an outside company. I need to get a price from the proto shop before the internal PO can be issued, then I need to send the money to the company purchasing the coolers. If the price is right and all agree then the second batch will be easy. I'm loking for 10 units to start ,but will not follow through unless the price is reasonable. If it isn't it would be easier dealing with a competitor. I've just about had it with our Thermal group! The Turbo guys will do anything for me at this point.
