Just had a Ex Lotus Mechanic take off my door panel to fix a window problem and he showed me a 2 sec removal of the dreaded orange door lock clip.
All he did was take a large screwdriver and "prize up" the clip off the ROD
it came off complete and then all he had to do was turn over the lock button and prize out the orange clip from the reverse side with NO BREAKAGE I could not believe how simple this was as the clip is held on to the rod which is a threaded shaft YOU DO NOT NEED TO TRY AND GET THE CLIP BIT OUT FIRST WHICH HOLDS THE ORANGE CLIP.
No more orange clips for me (the removal trick does work tho'
