by John_Ox » Fri 25.11.2005, 17:57
Help, My coolant system is loosing fluid abd i have been told by hr owen that its the water pump. could this be true.|?? Also i am failing to get any real heat from my heaters!!! i am toping up the coolant everyday! they are producing a small amount of heat but not enough to keep me warm in this weather\!!! would this be a faulty thermostat?
thanks in advance
John_Ox
by Dico » Fri 25.11.2005, 19:30
1 - possibly
2 - probably an air lock.
No point in trying to fix the heater problem untill the leak is sorted in my opinion.
- Fool Boy Four - Founder
by Doc Fizzix » Sat 26.11.2005, 02:33
I also say heater valve but you should check your drain plugs also, mine totaly disinagrated and were leaking away but this sounds more like the heater valve.
Doc Fizzix on Mon 28.11.2005, 20:15, edited 1 time in total.
Doc Fizzix
by John_Ox » Mon 28.11.2005, 12:33
Thanks i`ll try those suggestions see if it helps.
John_Ox
by John_Ox » Tue 29.11.2005, 19:27
where do i find the coolant valve? Sorry new at all this mechnical stuff!??
John_Ox
by theelanman » Tue 29.11.2005, 21:04
IIRC isnt it under the O/S headlight.....
open the bonnet and pop the headlights too and theres a black hex plastic screw thing under the O/S (well UK cars anyway)
cheers
G
by Candles » Tue 29.11.2005, 21:06
You have to reach between the coolant header tank and the engine block and the valve is hidden behind the intake plenum where two pipes come out of the bulkhead. Rather restricted access!
Candles
by billythec » Tue 27.05.2008, 23:54
Anyone confirm a properly working replacement part for the heater control valve? Didn't want to throw in the Napa 660-1200 unless someone can confirm it works the right way. The link suggested parts but didn't have any actual "follow up".
Thanks!!!
billythec
by Monty » Wed 28.05.2008, 11:43
- Chunder King!
by billythec » Wed 28.05.2008, 13:18
looks like the $50 jaguar part fits
billythec
by Coupeboy » Mon 23.06.2008, 13:11
Ref the cooling system bleed valve under the left headlight (UK cars only) - go easy on this as I just sheared mine off, maybe the plastic got old and had had enough. Yikes! Fortunately the headlamp is easy to remove and with a quick couple of holes from a drill, a screwdriver got it out. Tighten finger tight only - you have been warned - or better not to touch it all!
Coupeboy
