A single (driver's) aperture (a la the M200) in a GRP colour-co-ordinated tonneau-type cover/panel, with clear plastic screen/deflector.
It would cost a small fortune and would have to be made to fit after the seat and rollcage were in place but...?
Sy V wrote:You swine! You've got me thinking here.
Kuching wrote:The solution is to replace the backbone chassis with a tubular space-frame, which picks up on the spring/damper mounts, reacting the torsional loads through this large cross-sectional area structure. This way the weight could be reduced, dynamic control would be better, and you get a roll cage for free!
Kuching wrote:Philbo, I've been thinking along similar lines regarding the weight of the car for track use. As I see it, the backbone chassis layout fundamentally limits the torsional rigidity of the vehicle due to its very small cross-sectional area. Changing the material to aluminium would help with the weight but at the considerable expense of stiffness, further reducing the control that the dampers can have on vehicle dynamics. Any increase in spring stiffness for track use will compound this problem.
Sy V wrote:I'm eternally grateful too, don't get me wrong. But, whilst I hear what's being said about the chassis etc, I ain't going there!
