I recently took a Honda s 2000 for a test drive and the only thing that impressed me was THE BIG RED START BUTTON that you had to press to "fire up" the engine with.
So I had an idea? What would it feel like to "press the button" to "fire up" a LOTUS ELAN using this method. By chance I was on E-bay and came across a Company that sells a complete Kit for a Honda Start Button (see attached)
The kit comes complete with the relay and all the wiring and the only place I could think of where to fit it is in the blanking plate on the dash
for the two switches.
I made a blanking plate for the Start Button and removed the switches and the carrier plate behind. It was then a simple matter of removing the lower steering wheel shroud to expose the start switch and wiring and then splice into the start wire.
After fitting the BIG RED BUTTON it was time to "FIRE UP" the engine.
WOW I am a sad old sod
button as it is hidden by the steering wheel.
