Everest = Less ?
Postby Avonvilla » Mon 03.04.2006, 16:29
ESM wrote:Check all unions of the small vacuum pipes on the back of the plenum for leaks.
Thats what it was, the right angle one, looked like it had previously split and was superglued back together, it had just given up the ghost. Thanks Alan, star as usual :D
Avonvilla
Postby Avonvilla » Thu 11.05.2006, 09:52
Hmmm thread resurection i'm afriad :(
Well my problem has returned so whatever it is comes and goes although once it loses the power it seems to stay lost till tinkering here and there gets it back, trouble is i dont know what tinkering works :(
I can now tell by the seat of the pants it's down and also the boost gauge gives me pointers..............
When down i get a hiccup in boost delivery, plant the throttle in any gear at any revs and the gauge rushes to around .5 then it sort of stops for a short time, maybe only a second or part of and then rises from there progresively till approx .9 ish. Now i know the gauge is inaccurate and elanscan proves boost is eventually getting .9 but when it was working correctly the gauge just jumped right round to .9 and i could get wheel spin in 2nd :D
The boost solonid valve was chaged last year for a new one that didn't help, any ideas ? I have a dyno booked today which i know will give me about 135-140 at the wheels with the everest, i'll ask them too for ideas and heres hoping :?
Steve
Avonvilla
Postby Paul.P » Wed 26.07.2006, 20:26
Steve, did you get anywhere with this, i am having similar problems.
Postby Avonvilla » Fri 28.07.2006, 08:24
Paul.P wrote:Steve, did you get anywhere with this, i am having similar problems.
Not really, the dyno showed up lower boost than being shown on elanscan and the gauge which i dont understand as he took his feed for his reading from the gauges line. He suggested it was the BSV which i changed again but no differance. I really am lost by it and need to get them to do a full test but as it drives well apart from those extra horses i've put it off.
Avonvilla
Return to Upgrades
