Hood tensioning
Hood tensioning
Postby mickmick » Thu 20.04.2006, 11:32
Hello again folks,
So, now i have a reasonable heat coming from the heater, i have new coolant in the engine and i have just fitted a new (to me) S2 hood onto my SE, but i have a question:
Is it possible to tension up the rear part of the hood as mine is just a tad baggy, causing the rear screen to be a bit wavy as it isnt tight enough .
There you go, answers on a postcard to the usuall address!!! :lol:
Oh yeah, and before i forget
Thank you to Mike Y for having the hood, meeting me at a reasonable place and selling it to me
Mick K
now i have one, i just want to keep tinkering with it!!!!!!!
sorry mum :(
mickmick
Postby stevo » Thu 20.04.2006, 13:26
i think this is how it works, it sorted mine anyway.
the hood is tentioned by 2 cables that run across the tops of the windows. you'll see them come out at the back of the window and go into a screw clamp. this can be tightened.
stevo
Postby mickmick » Thu 20.04.2006, 13:33
Dont think i've been clear enough with my description
the front half is fine, its just the rear part with the screen in that isnt quite tight enough
hope the extra info helps
sorry mum :(
mickmick
Postby pjohn151 » Thu 20.04.2006, 13:50
Is it seated on the rear deck OK? I think that there is a small amount of adjustment in how far the back half folds down onto the rear deck...
Now Elanless
pjohn151
Postby mickmick » Thu 20.04.2006, 14:06
Just had another good look at the hood
the rear is down solid, and the tensioner webbing straps at the back are well tight, so i dont hink theres any room for adjustment
i guess its just a quirk you get with having a small converable sports car
Thanks for the replies
Mick K
sorry mum :(
mickmick
Postby pjohn151 » Thu 20.04.2006, 14:09
Is there any potential for lifting the hood slightly without the window seals missing the windows, and then adjusting the back?
Now Elanless
pjohn151
Postby TheBard » Thu 20.04.2006, 14:51
Adjusting the tension of the hood wires above the door would pull the rear screen/back panel flatter. Be warned though, the adjustment nut is ver fragile, and the slightest attempt to turn it can rip the head off.
Now where did I leave my drill :roll:
Good luck,
Ian
TheBard
to tighten hood up.
Postby johnbenk » Thu 20.04.2006, 16:14
Hi.
Daft as it may seems if you use "the hood ren-evate" stuff on sale at Moss, MG .Mx5. and TR spares or at "Frost" based in Rochdale.(www. frost.co.uk ) I think it called RENOVO this will "pull" the hood cover tighter.
You need a SUNNY DAY and apply as per instructions.
After application your Hood should like like new and to Happix material
will have tightened up.
Hope this helps.
JBK
johnbenk
The only Gay in the Village
Postby Dico » Fri 21.04.2006, 21:55
Think you will find its 'Rochdale', unless your Italian.
Spell Check
Postby johnbenk » Sun 23.04.2006, 08:07
Hi Dico
Was thinking of our "GRACY" and the isle of Capri and slipped in an extra
"A" :oops: :oops: :oops:
Sing as you GO GO :-D :-D :-D :-D :-D :-D :-D :oops: :oops: :oops:
johnbenk
Postby Dico » Sun 23.04.2006, 21:49
Think you will find its 'Gracie' unless you're from Salford.
Gracie it is
Postby johnbenk » Mon 24.04.2006, 16:37
Hi
Thanks for that Getting mixed up with other Gracy I think its May :oops: :oops: :-D :-D :-D :-D :-D :-D :-D
JBK
johnbenk
