What is the rim sepc for USA spec M100 Elan's 16in rim?
Postby kmckmc » Wed 26.04.2006, 03:21
Hi,
What is the rim spec for our USA spec M100 Elan?
Are there good selection of aftermarket rims? Where?
The USA spec M100 I am thinking of buying does not have original rims. I am thinking of either looking for used ones or buying new aftermarket rims, but I do not know what is it that I should specify.
Please advise.
kmckmc
Re: What is the rim sepc for USA spec M100 Elan's 16in rim?
Postby Doug » Wed 26.04.2006, 05:44
kmckmc wrote:What is the rim spec for our USA spec M100 Elan?
wheel = 16" X 7"
bolt pattern = 4 X 100
offset = +60mm
Center Bore: I measured the hub of my Elan CRUDELY to be about 56.5mm--this figure is not published in any Lotus literature.
Postby Fubar1764 » Wed 26.04.2006, 15:45
Best of luck! If you find non-OE rims with that offset, you'll make many here happy if feel somewhat foolish!
-Your "Jack" of all trades
Fubar1764
Postby Houdini » Wed 26.04.2006, 17:53
To correct Dougs information on the the center bore dimension it is 56,6mm (measured 6 rims)
The closest you can get to a 60mm offset is from Team Dynamics which has a light weight wheel that is 50mm offset. If you want the exact specifications for an aftermarket wheel you'll have to buy custom made rims from Kodiak or some other supplier ($400 a wheel plus). Custom rims are expensive (but worth it because of light weight) and rims that do not have the correct offset are not good for anything more than normal driving. If you do any spirited driving on the track or autox then you want the correct wheel because not having a 60mm offset will effect the excellent handling Lotus has designed.
Houdini
Postby Elanlover » Wed 26.04.2006, 21:41
I found some 17 x 7, +60 mm offset wheels while searching the web................ too bad they were all 5 bolt patterns :(
Postby Houdini » Wed 26.04.2006, 22:28
Hey, I've fould them in the 5 bolt pattern as well. I believe they're for a Mazda 6.
Houdini
Postby Elanlover » Wed 26.04.2006, 22:51
Houdini wrote:Hey, I've fould them in the 5 bolt pattern as well. I believe they're for a Mazda 6.
You're right! Both Mazda and for an Acura NSX actually.
Postby Doug » Thu 27.04.2006, 00:28
Houdini wrote:To correct Dougs information on the the center bore dimension it is 56,6mm (measured 6 rims)
thanks! I remembered someone quoting something before, but I remember it was darn close to mine. I didn't have the digital caliper I have now, and believe it or not that was the measurement from the nub with a steady tape measure . . . not too bad! Notice I did say "CRUDELY" measured. :wink:
Postby Houdini » Thu 27.04.2006, 17:43
Doug,
I cheated and brought a wheel to work and measured one just to verify what i measured at home. You did real good, because .1mm (.004") is pretty darn close. Actually it's more than likely within tolerance.
,Russ
Houdini
Postby F1 LOTUS » Thu 27.04.2006, 19:34
So all you need then is a 5 bolt conversion kit :twisted: :P
F1 LOTUS
Return to Wheels and Tyres
