by Leung » Mon 01.05.2006, 12:00
I am having a damp patch on the boot carpet,It is on the underside on part of the carpet,on the left hand side where it sits in a recess where the tool kit sits.It is only that square patch that is damp ,the rest is dry as a bone,I cannot see any water ingress so the only reason I can think of is the drain hole on the bottom of the car that is letting in damp air.Any thoughts?
Leung
by Specky » Mon 01.05.2006, 12:06
Check the old washer bottle isn't leaking... it happended to me..
by Candles » Mon 01.05.2006, 12:07
One of two things:
1) Boot windscreen washer reservior is spilling over and collecting there. Solution: Only fill half full!
2) Rubber bung in front face of the recess you mention is leaking water in from under the car when driving on wet roads. Solution: Remove bung and replace with sealant around it.
Hope that helps,
Candles.
Candles
by Leung » Mon 01.05.2006, 12:47
I dont think is the washer bottle because I did not put any water in it for the very reason! Anyway the bottle is on the other side of the boot and the damp patch is on the square recess on the left hand side.
Should there be a bung on the drain hole on the bottom of the car?because all I can see is an open hole.
Leung
by Specky » Mon 01.05.2006, 13:11
Leung wrote: Should there be a bung on the drain hole on the bottom of the car?because all I can see is an open hole.
Problem solved
by Doug » Mon 01.05.2006, 18:41
better fix your leaky bunghole
- LEC Founder
by TheBard » Mon 01.05.2006, 20:06
<groan>
and Doug wins 10 points!
TheBard
