by frog » Sat 06.05.2006, 15:49
Is there an easy way to remove the ashtray back? I can't see how to prise it out. Do I really have to take the dashboard out?!
I'm interested in fitting a GPS unit, with a surround so that the ashtray goes completely, but I have the touchscreen GPS in its place. I plan to cut an aluminium section out and attach the GPS unit to it to make it all tidy.
frog
by johnbenk » Sat 06.05.2006, 18:36
Hi
The surround is sometimes "glued in". You could try a Hot air gun to see
it will melt the glue. mind you dont melt the surround. Better try a " hairdryer" first.
johnbenk on Sat 13.05.2006, 13:53, edited 1 time in total.
johnbenk
- The only Gay in the Village
by frog » Sat 06.05.2006, 19:14
Hi,
Thanks - so the metal surround has no clips or anything holding it on! I'll give it a go, but 15 years of glue setting sounds tricky to remove...
frog
by johnbenk » Sat 06.05.2006, 21:29
Hi
On some car the surround would pull out with the ashtray. Previous owner may have glued the surround. Do not think it is metal though the part can be purchased as a seperate item part number a100V6015F.
johnbenk on Sat 06.05.2006, 21:35, edited 2 times in total.
johnbenk
by johnbenk » Sat 06.05.2006, 21:31
Hi
see photo:::::
johnbenk on Sat 13.05.2006, 13:53, edited 2 times in total.
johnbenk
by theelanman » Sat 06.05.2006, 21:38
erm...where did that pic come from??....just asking as I didnt know that the layout of the LHD cars changed from the RHD cars...either that of its just and 'inicative' sketch.....
my layout has swithches and ashtray located differently!!!
cheers
g
by Doug » Sun 07.05.2006, 08:37
yes, LHD and RHD have different gauge, clock, switch, and vent layouts
- LEC Founder
by JonRB » Mon 17.09.2007, 19:59
Sorry about resurrecting an old post, but did you get the ashtray out in the end? Was it just glued in?
JonRB
by JonRB » Wed 19.09.2007, 18:37
Just for future reference for anyone searching for the answer in the future, the back of the ash tray is indeed held in with glue and a hairdryer does melt the glue and allow you to take it out.
JonRB
by John Tsakas » Mon 24.09.2007, 14:09
Hi
Yes you must put all the dash panel out. I know because
i just buy a new dash panel and is fix with the ashtray
John Tsakas
- Tinkerer
by JonRB » Mon 24.09.2007, 18:14
John Tsakas wrote:Yes you must put all the dash panel out. I know because i just buy a new dash panel and is fix with the ashtray
Ok, but as I said in my previous post, mine was glued in and came out with the use of a hairdryer to melt the glue.
JonRB
Return to Interior
Users browsing this forum: AhrefsBot and 5 guests
