Coil, did anybody find a UK source?
Postby WillB » Wed 10.05.2006, 18:25
Looks like I need one.
Will
WillB
Postby nitroman » Wed 31.05.2006, 00:10
This should be available over there as it is the came coil used on all (that I know of) Buick 3.8L V-6 engines. http://www.drivewire.com/buickparts/catalog/buicklesabreignitioncoil.html
nitroman
Postby nitroman » Thu 01.06.2006, 04:01
The OE looks EXACTLY like the MSD coil doesn't it? Even the weather seal is exactly the same, right down to the colour. If the MSD coil wasn't red & had "MSD" printed on it you couldn't tell the difference.
nitroman
Postby JonRB » Thu 01.06.2006, 13:48
Just found out that our Elan M100 needs a new Ignition Coil and Lakeside Engineering say it is on back-order from Lotus and they don't know when it will be in.
So our Elan has to stay at LE until it arrives, I guess. :(
JonRB
Postby M100 TWO » Thu 01.06.2006, 17:17
Jon, Willb found www.americanautoparts.co.uk and quoted a GM part no 10468391 it worked well
john
M100 TWO
Postby JonRB » Mon 17.07.2006, 11:21
Thanks for the tip-off.
Fortunately Lakeside managed to source one for me before I had a chance to follow up on your lead.
JonRB
Postby Freelander » Wed 30.07.2008, 10:15
UK supplier for OEM Coils - listed as GM Part No 10468391 quoted by M100TWO
http://www.ignitioncoil.co.uk/searchres ... 1QodvDzqRA
1990 SE Turbo - Silver - Work in Progress (Slowly)
'Go slow now - go fast later'
Freelander
Postby Enright » Wed 30.07.2008, 12:45
Good price. Good lateral thinking too - I hadn't considered that we might share parts with the Lotus Carlton.
Also checkout the MSD Group Buy thread - I can vouch for them being really good and you may be able to get a set for about the same amount. A few people are interested in buying another run in the next week or two.
Postby a5gcd » Wed 30.07.2008, 20:06
Last year I got a complete coil pack for an Esprit from the Lotus spares sale, it is exactly the same as the one I took off. Part No A910E6940F
a5gcd
