by HGRACER » Tue 08.08.2006, 19:43
Anybody got any idea what the small water hose coming out of the pipe from the turbo is called and where is the best place to buy the said hose mine has a split and started leaking so I taped it up with hose tape and topped the water up every 5 minutes till I got home safely so its parked up just now till I get this hose thanks for the help.
Cheers Henry
HGRACER
- Tinkerer
by Andy C » Wed 09.08.2006, 04:22
The hose you describe is called something technical like "Turbo Water Feed Hose"
Mine gave way a few months ago and I replaced it with a generic hose from my local auto parts store .. easy job and worked fine. This was the thread when it happened
http://www.lotuselancentral.com/forum/viewtopic.php?t=6219
Once I had repaired this and went poking around at the other cooling system hoses, I found that many of them were in a similar state and needed replacing .. not surprising as they are all 10+ years old. I ended up replacing all hoses with the Samco kit. For peace of mind, a definite recommendation.
Andrew
Medina Green #296 Brians Wilwood Brakes, Everest Chip, Piper 2.25, PWR Cooling & ProTech Suspension
Andy C
by Andy_J » Wed 09.08.2006, 10:25
Henry
Assuming you mean the 'Trubo Water Feed Hose' (runs dirctly under the CAS) to the thermostat housing. These are still availble from lotus as I replaced the same hose 3 weeks ago.
Bought mine direct from Lotus dealer Christopher Neil. Cost about £10 including P&P delivered in less than a week.
Andy
90H BRG SE 48,000 Miles
Andy_J
by dans » Wed 09.08.2006, 10:31
Is it this hose?
This is the problem I had
here
Got a couple of them from a Lotus dealer for about £6.50. I gotta spare if you need it.
Dan
dans
by HGRACER » Wed 09.08.2006, 14:08
yeah that looks like the very one! I will try and get one ordered up then thanks for the help.
ps did you need any new clips when changing the hose if so what are they called
SJ have the hose in question for 2.41p so its not going to break the bank
HGRACER
- Tinkerer
by muley » Wed 09.08.2006, 21:17
Thinks....
"I know a few people have had problems with this hose. I think I'll replace it on the snotter as a precaution. I need to flush and refill the coolant, anyway."
by HGRACER » Wed 09.08.2006, 23:26
Dan if you still have that spare hose I will take it from you matey I have been trying to get hold of SJ all day and cant get them and with the car parked up at the house I really need to get it fixed and on the road asap so if you can send me it that would be great, I will pm you with my address and you can let me know how much it is and I will send out a cheque Thanks Henry
HGRACER
- Tinkerer
by HGRACER » Fri 11.08.2006, 18:38
Dan thanks for the hose I put it on today and everythings fine so thanks for the help I will buy you that pint if I ever have the chance Cheers Henry
HGRACER
- Tinkerer
by dans » Fri 01.09.2006, 18:01
No probs. Glad it worked!
Dan
dans
