by ESM » Sat 14.10.2006, 20:25
I've put a new beta version up on my site!
The excel export seems a lot faster to me but you can judge for yourselves.
ESM
by GeoffSmith » Sat 14.10.2006, 21:18
Good stuff Alan, only 25 seconds to load Sy's data.
- Kitty Fiddler
by mailman221 » Sun 15.10.2006, 06:35
Geoff or Alan, are you making cables as I need one?
mailman221
- Tinkerer
by M100 TWO » Sun 15.10.2006, 12:24
Me to !
M100 TWO
by donsladek » Sun 15.10.2006, 22:22
mailman221 wrote:Geoff or Alan, are you making cables as I need one?
Hi Geoff,
Is it time for an Elanscan Cable (unofficial)list?
1. mailman221
2. M100 TWO
3. donsladek
Cheers!
Don Sladek
Don Sladek
Calypso Red '91 #37594
donsladek
by GeoffSmith » Sun 15.10.2006, 23:27
Please look here for the
official ElanScan Interface list.
Geoff
GeoffSmith on Mon 16.10.2006, 09:44, edited 3 times in total.
- Kitty Fiddler
by GeoffSmith » Sun 15.10.2006, 23:38
Alan,
All looks good but I did have a minor gremlin. Some black and purple curves appeared on the chart - they covered a smaller timescale (est. a few %) than the rest of the data and I couldn't get rid of them by zooming, changing data etc. Re-running ElanScan got rid of them and I haven't managed to reproduce them since!
Geoff
PS Someone has plagiarised the ElanScan icon and used it on an online gaming programme
Don't ask how I came across it!
- Kitty Fiddler
by ratman » Mon 16.10.2006, 08:03
I have the SW, I have data (Test1.ecu), I haven't the cable.
I'm trying to learn how to use Elanscan, waiting for the cable but I'm not able to read the data because Elanscan gives error when I'm opening the file.
I tried also in test mode.
What I have to do? Thanks!
Lotus Elan S2 n°538
ratman
by GeoffSmith » Mon 16.10.2006, 09:44
Ratman,
If you e-mail me your .ecu file, I'll have a look for you.
Geoff
- Kitty Fiddler
by ESM » Mon 16.10.2006, 10:25
ratman wrote:I have the SW, I have data (Test1.ecu), I haven't the cable.
Could you send me the test1.ecu file? Also try the .ecu file Sy's recently linked on his Stripey2 project thread.
ESM
by ESM » Mon 16.10.2006, 10:26
geoffsmith wrote:Alan,
Geoff
If you can figure out how to induce it let me know - its not something I've come across before.
Re the plagarism - if you mean the icon the elanscan.exe file shows then it s not nicked from me, its the standard default icon Delphi (the software development package I use) puts on all applications it produces.
ESM on Mon 16.10.2006, 10:31, edited 1 time in total.
ESM
by ratman » Mon 16.10.2006, 10:31
here it is!
Lotus Elan S2 n°538
ratman
by ESM » Mon 16.10.2006, 10:43
I just loaded that file no problem with the ElanScan_beta.exe... What operating system are you using and could you send a screen dump showing the error?
ESM
by GeoffSmith » Mon 16.10.2006, 12:33
No problems with the two ElanScan versions or my Excel import routine.
- Kitty Fiddler
by ratman » Mon 16.10.2006, 13:37
perhaps is because I'm not the administrator in this pc!!!
Lotus Elan S2 n°538
ratman
by GeoffSmith » Mon 16.10.2006, 13:59
Ratman,
You are correct. ElanScan attempts to write the initialisation file "M100 ALDL protocol.ini" into the windows directory when it is first run, so you should load/run it the first time as an administrator. On subsequent runs I don't believe you need to have write privileges so you need not be logged in as an administrator.
Let us know how you get on.
Geoff
- Kitty Fiddler
by ESM » Mon 16.10.2006, 14:42
Ok maybe I can fix it... I'll change the .ini location to
c:\documents and settings\application data\Elanscan
or something like that.
ESM
by ESM » Mon 16.10.2006, 18:55
Another new version is up. A couple of things have been done....
ESM
by GeoffSmith » Mon 16.10.2006, 19:18
Crop and copy work a treat but just a couple of minor observations:
Cursor details "Point X of Y" are not updated after cropping until after the cursor is moved.
The curve line style/colour and points shape/colour revert to default.
Otherwise excellent mods which make export to Excel damned fast once the data of interest has been selected.
Geoff
- Kitty Fiddler
Return to ElanScan
