daveyg wrote: Could you route the vac solenoid (the actual part that connects to the secondary butterfly) directly to the manifold? that way, you'd have vacuum holding them closed in the low end, and boost holding them open top end? Just wondering... that way, the secondaries would always open immediately when boost hits, not necessarily at 4700rpm...
ESM wrote:I can't see how you think it'll do any good when the ECU will not know you've opened the secondaries early and so won't adjust the fueling. If you improve the VE (that's questionable) you'll simply push it leaner.
Sy V wrote:Just to complicate matters, Doc.
Don't forget that only the Fed, S2 and some Euro Elans (French Spec for sure) have a O2 sensor.
Doc Fizzix wrote:I know I am most likley way off but I would just like to learn more about this concept and how the computer in our car does work. From my years studing Bosch injection systems I think the Bosch computer would have been able to measure the increased air flow and adjusted the gas.
Aurora40 wrote:I'm no expert, but I would say generally speaking, if you have a computer-controlled engine, it's not a good thing to misinform the computer as to what is going on in an attempt to improve performance. That's just a good way to either have the car run poorly or dangerously. If you want to change something, change the programming too so the computer can still adequately control it.
isuzuimark wrote:opening the secondaries sooner wont help with the performance using the stock turbo. It will actually hurt it by decreasing the intake velocity as well and increasing turbo lag by having extra runners to fill.
