Drivetrain problems
by davidh » Wed 06.12.2006, 02:35
Driving into work today suddenly found myself stuck in 2nd gear. I assume that one of the cables has given up at the transmission end. I may have a spare cable but not sure which one. If it cannot be moved from second presumably that is the fore and aft cable?
davidh
- Tinkerer
by Dave M » Wed 06.12.2006, 19:43
It sounds like it. Does the shifter lever move back and forth but it not come out of gear? Or does the level not move at all?
Dave M
by davidh » Thu 07.12.2006, 01:03
At the time this happened the shifter lever appeared frozen but when I tried it tonight it moved backwards and forwards with no sideways movement. Very limp! I think I can hear the whole cable inner and outer sliding in the transmission tunnel. The gearbox end appears normal with the cables still firmly attached. I am assuming that it is the plastic on the outer cable that has gone at the gear shift end. I have not managed to remove the socket screws holding down the gear leaver lower gaiter and gear lever mechanism
so that is not confirmed.
Drove home in a tropical storm pitch dark hoping not to have any uphill starts. Still stuck in second.
Do you know where the gear cable change write up went?
davidh
- Tinkerer
by davidh » Mon 11.12.2006, 00:53
This weekend I opened up the the gearshift and discovered that in fact the fore-aft cable had broken completely just at the point that the flexible wire cable is joined to the solid end fittings. Fortunately when I bought the car 3 years ago it came with some spares and luckily one of the spares was a single gear cable.......... the correct one.
It was not fun changing it but the result is a gear change that is much smoother than before as the cable is not frayed.
davidh
- Tinkerer
