by GeoffSmith » Wed 04.10.2006, 19:13
Can anyone convert to DXF format or know of any decent (free) converters? I'd like a representation of the cat in dxf to go on my pcb's.
Geoff
- Kitty Fiddler
by TStevens » Wed 04.10.2006, 19:31
What type of software opens a DXF file?, exscusing my ignorance, and PCB's?
With some idea of what it is I can see what I can do for you, I have many friends in IT that may have the answer.
TStevens
by TStevens » Wed 04.10.2006, 19:32
TStevens
by GeoffSmith » Wed 04.10.2006, 20:16
Tony,
Sorry for slipping into acronyms so quickly! DXF is a format common in computer aided design (CAD) and I believe it is vector based so it is readily and accurately re-scaleable. I wanted to put the image on the elanscan interface printed circuit boards (pcb's) and the only format our pcb layout tools will accept is dxf. I didn't want to learn a new overly complicated tool for such a trivial task so thought I'd ask in case anyone was aware of any simple tools. Given Brian(F1Lotus)'s CAD/CAE expertise, I'm still hopeful that might be able to help.
Thanks,
Geoff
- Kitty Fiddler
by markv » Thu 05.10.2006, 01:06
Going back to my CAD days, I think DXF format was an Autocad format which became a defacto standard
by theelanman » Thu 05.10.2006, 12:53
am running auto cad 2007...standard software for me along with microstation......who wants what?????....and into what??...
I'll have a go if you let me know cheers
Gareth
DXF = drawing exchange format!!!
industy standard for swapping drawing between different software
by GeoffSmith » Thu 05.10.2006, 14:17
- Kitty Fiddler
by F1 LOTUS » Thu 05.10.2006, 15:50
I should be able t do this for you
F1 LOTUS
by theelanman » Thu 05.10.2006, 16:12
in order to get you line weights Id import it into cad and line it out...then delete the imported jpg and save it as a dxf (and a dwg whilst I'm at it)
dont know if brians method is easier......Ive not got an image modifier that I can link up so if brian got somethiong faster then I'll leave it in his capable hands....plus the fact I'll be away for a couple of weeks from monday so if I have a crack at it it'll be this weekend......but if I dont then it'll be when I get back
cheers
G
by theelanman » Thu 05.10.2006, 16:35
geoff
you have email!!!!!!
cheers
g
by GeoffSmith » Thu 05.10.2006, 23:16
Thanks both of you. Now all I've got to do is to get all my applications re-loaded on my new pc to be able to see them!
Fun, fun, fun........
- Kitty Fiddler
by GeoffSmith » Fri 13.10.2006, 00:52
Brian,
HELP!
Gareth's .dxf looks fine but when I import it into a 1" × ½" pcb, the board ends up twice as big as the Elan and I can't see a cat on the screen - if I'm lucky I get one pixel! I think the problem is that it is offset from the origin and with my limited tool/knowledge, I can't re-centre it. Is there any chance you could do a quick fix?
Geoff
- Kitty Fiddler
by GeoffSmith » Fri 13.10.2006, 20:09
Brian,
You've got an e-mail.
Geoff
- Kitty Fiddler
by F1 LOTUS » Sat 14.10.2006, 19:44
geoffsmith wrote:Brian,
Geoff
Geoff,
Brian
F1 LOTUS
by GeoffSmith » Sat 14.10.2006, 20:10
Brian,
You are the selcitset staC! Thanks a lot.
Geoff
- Kitty Fiddler
by F1 LOTUS » Sat 14.10.2006, 20:20
My pleasure
F1 LOTUS
My pleasure
Twice
F1 LOTUS
