DXF format
Threads for help with computer maintenance, software and hardware advice, photos and photoshopping, and other topics related to keeping your computer healthy and online with us.
DXF format
Postby GeoffSmith » Wed 04.10.2006, 19:13
Can anyone convert to DXF format or know of any decent (free) converters? I'd like a representation of the cat in dxf to go on my pcb's.
Geoff
Postby TStevens » Wed 04.10.2006, 19:31
What type of software opens a DXF file?, exscusing my ignorance, and PCB's?
With some idea of what it is I can see what I can do for you, I have many friends in IT that may have the answer.
TStevens
Postby TStevens » Wed 04.10.2006, 19:32
TStevens
Postby GeoffSmith » Wed 04.10.2006, 20:16
Tony,
Sorry for slipping into acronyms so quickly! DXF is a format common in computer aided design (CAD) and I believe it is vector based so it is readily and accurately re-scaleable. I wanted to put the image on the elanscan interface printed circuit boards (pcb's) and the only format our pcb layout tools will accept is dxf. I didn't want to learn a new overly complicated tool for such a trivial task so thought I'd ask in case anyone was aware of any simple tools. Given Brian(F1Lotus)'s CAD/CAE expertise, I'm still hopeful that might be able to help. :poke:
Thanks,
Geoff
Postby markv » Thu 05.10.2006, 01:06
Going back to my CAD days, I think DXF format was an Autocad format which became a defacto standard
Postby theelanman » Thu 05.10.2006, 12:53
am running auto cad 2007...standard software for me along with microstation......who wants what?????....and into what??...
I'll have a go if you let me know cheers
Gareth
DXF = drawing exchange format!!!
industy standard for swapping drawing between different software
Postby GeoffSmith » Thu 05.10.2006, 14:17
Gareth,
It's me! I'm sat at home, bored out my box with shingles so please humour me!
I would like the cat on skates converted into a dxf file for cutting onto printed circuit boards; the image will end up about 1/4" square with 8 thou wide lines so it probably doesn't need to be too detailed! My pc is still bust so I haven't even had a chance to try converting the image to an outline with Paintshop - I don't know whether you can do that with Autocad. Don't waste too much effort on it, but if you can do something, that would be great.
Geoff
PS just looked at your profile and realised why you've got Autocad - another ruddy engineer! There seems to be a few on this forum but very few hairdressers apparently.... :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D . :gray: . :wink:
Postby F1 LOTUS » Thu 05.10.2006, 15:50
I should be able t do this for you :D
F1 LOTUS
Postby theelanman » Thu 05.10.2006, 16:12
in order to get you line weights Id import it into cad and line it out...then delete the imported jpg and save it as a dxf (and a dwg whilst I'm at it)
dont know if brians method is easier......Ive not got an image modifier that I can link up so if brian got somethiong faster then I'll leave it in his capable hands....plus the fact I'll be away for a couple of weeks from monday so if I have a crack at it it'll be this weekend......but if I dont then it'll be when I get back
cheers
G
Postby theelanman » Thu 05.10.2006, 16:35
geoff
you have email!!!!!!
cheers
g
Postby GeoffSmith » Thu 05.10.2006, 23:16
Thanks both of you. Now all I've got to do is to get all my applications re-loaded on my new pc to be able to see them!
Fun, fun, fun........ :asleep:
Postby GeoffSmith » Fri 13.10.2006, 00:52
Brian,
HELP!
Gareth's .dxf looks fine but when I import it into a 1" × ½" pcb, the board ends up twice as big as the Elan and I can't see a cat on the screen - if I'm lucky I get one pixel! I think the problem is that it is offset from the origin and with my limited tool/knowledge, I can't re-centre it. Is there any chance you could do a quick fix?
Geoff
Postby GeoffSmith » Fri 13.10.2006, 20:09
Brian,
You've got an e-mail.
Geoff
Postby F1 LOTUS » Sat 14.10.2006, 19:44
geoffsmith wrote:Brian,
Geoff
Geoff,
Brian
F1 LOTUS
Postby GeoffSmith » Sat 14.10.2006, 20:10
Brian,
You are the selcitset staC! Thanks a lot.
Geoff
Postby F1 LOTUS » Sat 14.10.2006, 20:20
My pleasure :lol:
F1 LOTUS
My pleasure :lol:
Twice :?
F1 LOTUS
Return to Computer Help / IT Area
