Rubber "A" Pillar Seals.
Re: Rubber "A" Pillar Seals.
Postby absm100 » Mon 10.11.2014, 21:37
I received my A pillar seals courtesy of Jamie and I must say I was very impressed, firstly the quality and fit of the seals were extraordinary. I was a little apprehensive as I expected an obviously home made part but what I received could easily have equaled if not bettered commercially available seals. seeing is believing...!
So how did it go? To start with removing the old seals took me about two and a half hours, this was exactly what I expected as Jamie's very detailed instructions prepared me for a bit of a task, he also included a useful drawing of the necessary tool for removing the old sealant from inside the channel . Whilst not difficult it was time consuming due to the old sealant which was applied all along the channel on the original seal. Channel cleared and cleaned I then took Jamie's advice and replaced the screws top and bottom of the screen with stainless replacements.
The next part installing the new seal was completed in just a few minuets I was expecting a struggle but after offering up the seal and moving the push stud to the inside hole thoughtfully provided :) I guess to accommodate different versions of the seal, everything lined up perfectly yes I said perfectly! amazing given the subtle differences between each and every Elan I never expected that.
Next I pressed home the seal as per instructions and dared to remove it again just to prove to myself that it was a good snug and tightly fitting replacement, and hey-presto impressive...! I now understood why Jamie's instruction made new sealant optional. I did however use a small amount at the top as recommended to keep the top of the seal in place and watertight.
Well that's it my new A Pillar seals fitted in seconds, I live on the south coast and the bleak weather windy squalls and frequent down-poring cant get past my new seals. :D
If you are considering buying these EPDM seals from Jamie my advice would be don't hesitate! these are A Pillar seal upgrades all the way.
Thank you Jamie and Thank you Lotus Elan Central.
absm100
Postby Jamie N » Wed 12.11.2014, 18:35
Thanks for the kind words Tony, glad you found them so easy to fit. As I've said before once the bracket is cleared of all the old sealant and bits of sponge, fitting them takes literally 2 minutes and no need to bond them in permanently with sealant ( they fit into the bracket in such a way as to be sealed watertight by pressure alone and are gripped firmly ) so you can remove them as many times as you like. Used with the rubber door seals as well, they are as watertight a setup as you will find .
I still have 2 or 3 pairs available in anyone needs them, and clean as a whistle :wink: .
Monaco S2 #406
Jamie N
Seal God
Postby alan e » Wed 12.11.2014, 18:58
Hi Jamie what's the price for a set
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby Jamie N » Wed 12.11.2014, 19:13
alan e wrote:Hi Jamie what's the price for a set
Alan I don't have any full sets for sale, only the A pillars, and door surround seals (which require modification as per the thread in the Hood section), sent you a message. :wink:
Monaco S2 #406
Jamie N
Seal God
Postby alan e » Wed 12.11.2014, 19:34
Sorry I ment the A pillar set believe it or not I replaced both door seals when I got the car.
2010 black evora
MG ZS EV
alan e
Postby alan e » Thu 13.11.2014, 22:46
Jamie you have a PM
2010 black evora
MG ZS EV
alan e
Postby alan e » Fri 14.11.2014, 19:16
Hi Jamie new PM sent to you
2010 black evora
MG ZS EV
alan e
Postby Jamie N » Fri 14.11.2014, 20:39
alan e wrote:Hi Jamie new PM sent to you
Replied :wink: .
Monaco S2 #406
Jamie N
Seal God
Postby Sport Paolo » Sun 16.11.2014, 08:33
Jamie, you have new pm.
Sport Paolo
Postby andy111s » Mon 01.12.2014, 08:20
Another PM...
andy111s
Postby fillpoke » Sun 07.12.2014, 20:58
Hi Jamie - are the A post seals still available? Thanks, Dave
fillpoke
Postby Jamie N » Sun 07.12.2014, 21:48
fillpoke wrote:Hi Jamie - are the A post seals still available? Thanks, Dave
Affirmative Dave.
Monaco S2 #406
Jamie N
Seal God
Postby fillpoke » Sun 07.12.2014, 21:57
Could you let me know how much a pair would cost me please including p&p to Hartlepool?
Regards,
fillpoke
Postby joseazevedo1978 » Tue 16.12.2014, 00:21
Hello
Do you still have for sale a pair of Rubber " A" pillar.
I from portugal.
Please tell me?
best regards
joseazevedo1978
Postby donsladek » Tue 17.02.2015, 05:04
Hello, Jamie N,
If you have or will be making any additional A-pillar seals, I'm interested in purchasing a pair. Let me know if this is a possibility - they look really good, and appear to be easy to install after the old are cleaned out of the way!
Best regards,
Don
Don Sladek
Calypso Red '91 #37594
donsladek
Postby jimp357 » Fri 20.02.2015, 11:55
If these do indeed become available again, please put me down for a set.
Cheers.
VORSICHT! Die Nordschleife ist gefährlich.
jimp357
Postby Jamie N » Fri 20.02.2015, 19:01
I definitely have 2 pairs, possibly 3, locked away in the safe for, eh.... safekeeping :D .
Monaco S2 #406
Jamie N
Seal God
Postby donsladek » Fri 06.03.2015, 17:39
Received the seals from Jamie yesterday - they look fantastic!!
Quick shipping and the included instructions should make the job easy.
:cheers: Jamie!
Don Sladek
donsladek
Postby Ashaman » Wed 18.03.2015, 15:01
Hello, is there another set available? Could you please provide me with pricing information? Thanks!
Ashaman
Postby theelanman » Wed 18.03.2015, 15:25
Ashaman wrote:Hello, is there another set available? Could you please provide me with pricing information? Thanks!
and me please
thanks
